Page 3 of 3 1 2 3
Re: Nostalgia Pro Stock - Super Stock Springs [Re: B3422W5] #2981730
11/04/21 04:36 PM
11/04/21 04:36 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
I’m going to start my own thread with launch videos. I can use some advice in shock settings etc… the car keeps unloading and spinning
Re: Nostalgia Pro Stock - Super Stock Springs [Re: JACK1440] #2982064
11/05/21 01:37 PM
11/05/21 01:37 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I'd probably get in contact with Greg Luneack and get a pair of Tri-City Launcher springs as opposed to fighting some unknown 002/003 springs if you really want to avoid the Cal-Tracs or ladder bars. The Leaf-Link will rip the spring eyes out of the leaf springs, not to mention oblong the mounting points.
If it was my car, and the provisions are there for the ladder bars, then I would do a ladder/leaf floater setup at the power levels you're looking at.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: BigBlockGTS] #2982247
11/05/21 11:34 PM
11/05/21 11:34 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Yes... exactly. I have a "legal" SS/BA car that has a ladder bar and coil over. I am well aware of the "advantages". I'm just trying to keep this new project "period" correct as the safety part of things allows.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: Greenwood] #2982309
11/06/21 10:12 AM
11/06/21 10:12 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Originally Posted by Greenwood
An alternative- My bracket Dart has an Art Morrison 4-link in it, on leafs. The springs were moved into the frame rails, and I floated the housing by making a split aluminum bushing. The bushing properly locates the housing, and simply uses four 3/8 bolts that run through to a plate under the spring. It's genuinely slick, and will also give you the proper period correct look.
That sounds pretty cool. You wouldnt happen to have a pic or 2 of that would you? smile
Page 3 of 3 1 2 3
