Safety equipment for street/strip rides. Let's hear em'.
#2980332
10/31/21 06:42 PM
10/31/21 06:42 PM
Posts: 21,645 San Jose,CA
migsBIG
YouTube is my go-to news source
San Jose,CA
After seeing the thread on the transmission going nuke in that a-body, I realized I have not given much though to safety equipment. Though by build is a long ways off, I should consider stuff for my ride that will keep me and others safe for when I finally get to go down the track. I was planning on padded roll cage, trans blanket, fire suppression system, fuel cut-off, fuel cell and helmet with suit in case something turns ugly with a capitol 'fugly'. It's been about 12 years since anyone I known had a bad accident racing at the track, but almost every few months I having a friend/associate that got their ride ker-smashed and totaled from street racing/drifting/speeding. I have some ideas on stuff, and depending on the class, that dictates what equipment you have to run. Probably be prudent to run safety equipment/mods that are not required, but still beneficial. Thinking when I start running, but to build for a car that will be safe, even if it's not fast enough for that class. Would love to hear some suggestions. I was also thinking that other could benefit from some info. WOuld like to think everybody could have a little extra safety in their rides.
Re: Safety equipment for street/strip rides. Let's hear em'.
[Re: squirrel]
#2980337
10/31/21 07:02 PM
10/31/21 07:02 PM
migsBIG
San Jose,CA
It all depends on how fast you'll go, as you've noticed. Since you gave us no clue as to how fast you think you'll go, we can only make wild guesses.
This was not about how fast I was planning to go, but what people should think about for safety equipment/precautions should be used, regardless of speed of the vehicle. Though if you must know, I would like to brake 10's and be able to drive the truck to and from events.
[Re: migsBIG]
#2980339
10/31/21 07:10 PM
10/31/21 07:10 PM
Posts: 147 AZ
squirrel
AZ
Thanks, that makes it easier. The stuff required by NHRA to run tens is not to difficult to deal with in a street car. A roll bar or cage, with appropriate padding, and the necessary harness, are really the only things you'll deal with in normal driving. The other stuff you needs, such as driveshaft loop, trans shield, flexplate, battery and fuel related things, etc are just things you do when building the car. Just read the rule book carefully, then post your plans so others with some experience might give a few tips to make sure you're doing it right.
As far as general safety precautions--don't drive like a dick. Respect the power you have available, only use it when it's appropriate.
[Re: tboomer]
#2980367
10/31/21 08:53 PM
10/31/21 08:53 PM
migsBIG
San Jose,CA
Safety equipment? Fire extinguisher! I was just checking this out last week. Seemed like a good idea. Firesense fire system
[Re: migsBIG]
#2980408
10/31/21 10:52 PM
10/31/21 10:52 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I have a padded roll bar, fire extinguisher, 5 point harnesses, ( anyone that rides with me has to put it on), Super sprag, bullet steel front drum, and a blanket.
[Re: quickd100]
#2980412
10/31/21 11:01 PM
10/31/21 11:01 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have engine catch tray. Transmission shield, accusump for priming and low oil pressure emergency needs, 2 driveshaft loops (front and rear), neutral safety switch, roll cage, window net, 5 point harnesses, parachute, fire suppression system in both engine bay and pointed at me in passenger compartment, also small fire extinguisher mounted to cage. Yes, all in my street cat. I take the parachute off on the street.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: migsBIG]
#2980495
11/01/21 10:31 AM
11/01/21 10:31 AM
Posts: 4,206 New York
polyspheric
New York
Tool box, jack, stands, etc. in the trunk? Secure them with seat belts (E-booger learned me that). If not, it becomes a skull fracture when the car T-bones, spins, flips, rolls.
Boffin Emeritus
[Re: moparx]
#2980595
11/01/21 03:09 PM
11/01/21 03:09 PM
polyspheric
New York
That's what "etc." means...
Boffin Emeritus
[Re: migsBIG]
#2980601
11/01/21 03:20 PM
11/01/21 03:20 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Good luck on your goals Now get to work I don't envy you, I hope you get it done. How much does it weigh now? 4600 Lb.+ ? I'm thinking you need to he shooting for 750HP+
[Re: jcc]
#2981627
11/04/21 12:40 PM
11/04/21 12:40 PM
Posts: 19,402 north of coder
moparx
