Page 3 of 3 1 2 3
Re: 1200 Horsepower options? [Re: cuda499] #2978980
10/27/21 04:58 PM
10/27/21 04:58 PM
As far as happy scales and engine and chassis dyno, if they are NOT calibrated correctly they are not giving you correct information twocents, been there and had that done to me several times whiney
I've seen many engine dyno rooms have test room have positive air pressure inside of them due to the inlet fan for outside air flow more CFM than the exhaust fans did resulting in positive pressure in the dyno cell tsk Talk about phony results due to the positive inside pressure, it is just like adding 1 to 3 Lb. boost to the motors shock down
Re: 1200 Horsepower options? [Re: cuda499] #2979196
10/28/21 10:24 AM
10/28/21 10:24 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
There are alot of single cell happy dyno's out there for sure. As mentioned the track will tell for sure. All 42 of our dyno rooms are SAE calibrated and certified for all of our OEM and prototype development we do, so I know when we dyno engines are numbers are true.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1200 Horsepower options? [Re: n20mstr] #2979805
10/30/21 08:34 AM
10/30/21 08:34 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Has to be a Carb No injection
Re: 1200 Horsepower options? [Re: Mpetros] #2979809
10/30/21 08:49 AM
10/30/21 08:49 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Here is the Rules
Re: 1200 Horsepower options? [Re: Mpetros] #2979813
10/30/21 08:55 AM
10/30/21 08:55 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
You are allowed a aluminum block,
But I want to stay with Iron. Just the time I build a aluminum block they probably will change the rule to iron
Re: 1200 Horsepower options? [Re: Mpetros] #2979886
10/30/21 12:39 PM
10/30/21 12:39 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
No weight rule or minimum?
Re: 1200 Horsepower options? [Re: Al_Alguire] #2979988
10/30/21 05:50 PM
10/30/21 05:50 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Don't know if I fully understand this, but if factory BS is at play, no better option than a big Ford. A thor headed ford, would dominate any manufacturer. Chevy and mope would be way behind if there is something other than just anything goes.
For a mope, I still haven't seen anything better than a good set of predators. Better than any hemi NA that I've seen so far.
I've been playing with a pair of mechanical injected blown hemis in two cars, and have let my predator motors languish. I'm building a 4.9 bs noonan and having the second frame rail added to my stratus to deal with it. My plan is to take the 660 nitrous predator in it now, and make it NA single 4 over the winter using a get'm carb. I'll post progress as it goes.
What is this class you guys are talking about called?
Re: 1200 Horsepower options? [Re: dthemi] #2979990
10/30/21 05:59 PM
10/30/21 05:59 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
He has a pulling truck.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 1200 Horsepower options? [Re: dthemi] #2980041
10/30/21 08:37 PM
10/30/21 08:37 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Look up Undertaker Pulling on You Tube. Appalachian Outlaw or Super Street.
I have a Yellow Dodge. The class has lots of Professional Engines, Oakley, BES, Steve Schmidt
Re: 1200 Horsepower options? [Re: Mpetros] #2980148
10/31/21 09:59 AM
10/31/21 09:59 AM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
It's tough when you diehard Mopar knowing that this stuff's available to your competition for this kind of price
Re: 1200 Horsepower options? [Re: Mpetros] #2980260
10/31/21 02:56 PM
10/31/21 02:56 PM
AndyF Offline
AndyF  Offline
Yep, that is a good deal. We just paid more than $30K for a 572 Mopar wedge long block and it won't make anything close to 1200 hp. For $30K you can probably get a cast iron 572 Mopar wedge with 572-13 heads that will make 1000 hp. I don't think you can build a 1200 hp Mopar for $30K using all new parts.
Re: 1200 Horsepower options? [Re: birdtracker] #2987948
11/22/21 06:31 PM
11/22/21 06:31 PM
Greensburg, Pa
Mpetros Offline OP
Mpetros  Offline OP
Greensburg, Pa
Is there one advantage over another to use a wedge or a hemi block with a Predator head?
Is one way or another better or easier with reliability
Re: 1200 Horsepower options? [Re: Mpetros] #2987993
11/22/21 07:58 PM
11/22/21 07:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hemi pattern heads are a bit better some believe. We have had Slawko do both and didn't see any difference.
Re: 1200 Horsepower options? [Re: Mpetros] #2988024
11/22/21 09:22 PM
11/22/21 09:22 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Hate to point this out, but the BBC and BBF (FF, 385) are not wedge engines.
Boffin Emeritus
Re: 1200 Horsepower options? [Re: Al_Alguire] #2988096
11/23/21 02:34 AM
11/23/21 02:34 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you ever went the billet block route, Hemi blocks would be more readily available.
Alan Jones
Page 3 of 3 1 2 3
