Where on the trunk lip is the shipping number stamped? #2978884
10/27/21 12:18 PM
10/27/21 12:18 PM
Aurora, CO
jbeintherockies Offline OP
Aurora, CO
Hello,
On a 1968 Barracuda, where exactly on the trunk lip is the shipping number stamped? The shipping number is found on bottom right of the fender tag. I can clearly see the number stamped on the radiator core support. But I'm not sure where to look for it on the trunk lip.
Thanks!
Re: Where on the trunk lip is the shipping number stamped? [Re: jbeintherockies] #2978945
10/27/21 02:42 PM
10/27/21 02:42 PM
Cab_Burge Online work
Cab_Burge  Online Work
Left hand side of the trunk edge under the rubber gaskets is were I have found the sequence number on other Mopars, I've never looked for one on a 1968 Baracuda shruggy
My 1969 Dart GTS has it there also upscope
Re: Where on the trunk lip is the shipping number stamped? [Re: Cab_Burge] #2979569
10/29/21 12:25 PM
10/29/21 12:25 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
DR SIDE TRUNKLIP NEAR CENTER....UNDER SEAL... LOOK FROM THE BOTTOM WITH A MIRROR AND YOU CAN READ IT
Re: Where on the trunk lip is the shipping number stamped? [Re: ph23vo] #2979625
10/29/21 02:46 PM
10/29/21 02:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's what a '68 B-body looks like.
Re: Where on the trunk lip is the shipping number stamped? [Re: John_Kunkel] #2979748
10/29/21 10:20 PM
10/29/21 10:20 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
68 Barracuda Notchback.
I am pointing to where it is under the weather strip and the underneath
Yes the bottom right of the fender tag will be stamped
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
