rear axel lube #2979473
10/29/21 02:35 AM
10/29/21 02:35 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
what oil to use in a 8 3/4 L S
got a bottle of valvoline vv831 with for limited slip right on front label ! 80 / 90
got a new bottle of valvoline vv831 and not limited slip on label and rear states for top off only ????????? 80 / 90
thank you !
Re: rear axel lube [Re: calrobb2000] #2979520
10/29/21 09:36 AM
10/29/21 09:36 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With a cone SG use that straight up , with a clutch SG add some friction modifier . Ford dealer has the good stuff twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: rear axel lube [Re: fourgearsavoy] #2979601
10/29/21 01:25 PM
10/29/21 01:25 PM
moparx Offline
moparx  Offline
"Ford dealer has the good stuff".......
i always thought the GM stuff was the thing to get ? shruggy
what is the real scoop, and what is the difference between the two ?
how do these compare between jeep, ram, and even say, yukon friction modifier ?
i will say one thing about the yukon stuff. my wife's 94 concorde has had a converter shudder in OD at between 1800-2000rpm for years. above or below this range, no problem. no excess junk in the pan, fluid bright cherry red, no bad smell. somewhere i read about dumping a tube of yukon stuff in would fix that. well, i did, and immediately, the shudder was gone ! i couldn't believe it ! and that was several thousand miles ago, and hasn't returned since ! boogie
beer
Re: rear axel lube [Re: moparx] #2979602
10/29/21 01:28 PM
10/29/21 01:28 PM
The Ford additive still has the good old whale oil in it up scope
GM is suppose to have a similar synthetic additive down twocents
I use Red Line Synthetic Super Lightweight Shockproof gear oil, the green stuff in my S/P car with a spool up scope
I'm sure it says that it is compatible with all posi type rear ends scope shruggy
