"Ford dealer has the good stuff".......
i always thought the GM stuff was the thing to get ?
what is the real scoop, and what is the difference between the two ?
how do these compare between jeep, ram, and even say, yukon friction modifier ?
i will say one thing about the yukon stuff. my wife's 94 concorde has had a converter shudder in OD at between 1800-2000rpm for years. above or below this range, no problem. no excess junk in the pan, fluid bright cherry red, no bad smell. somewhere i read about dumping a tube of yukon stuff in would fix that. well, i did, and immediately, the shudder was gone ! i couldn't believe it ! and that was several thousand miles ago, and hasn't returned since !
