Isky bushed lifter rebuild qun
#2977421
10/22/21 10:35 PM
10/22/21 10:35 PM
Posts: 632 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Hey guys quick qun - anyone done this recently and what was the cost?
Anyone have the email contact for the guy @ Iskywho handles bushed lifter checking/rebuilds?
Thanks !!
Re: Isky bushed lifter rebuild qun
[Re: LAD 524]
#2977603
10/23/21 02:47 PM
10/23/21 02:47 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
Not that I'm aware of, sorry.
[Re: LAD 524]
#2977651
10/23/21 05:11 PM
10/23/21 05:11 PM
Posts: 2,490 Sydney,Australia
tex013
Sydney,Australia
LAD , Every time i need a specific answer i ring USA straight up . Often emails go missing or unanswered . Cheaper and simpler to call @ 6.30/ 7am especialy as Isky is west coast .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: LAD 524]
#2977773
10/24/21 04:31 AM
10/24/21 04:31 AM
tex013
Sydney,Australia
Just dont ring monday our time Even with Vette/ GM stuff i work on it pays to ring Tex
[Re: superbee69]
#2977890
10/24/21 02:47 PM
10/24/21 02:47 PM
Posts: 10,607 Rittman Ohio
fourgearsavoy
Rittman Ohio
RAU did mine , grind &hard chrome shafts, bush and hone arms plus 4 extra, 2 int 2 ex ,new spacers, adjusters. I went through The car shop I moline IL I droped them off they did the shipping and calling . cost right at 700.00 I think he needs lifter rebuild services .
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: LAD 524]
#2977912
10/24/21 04:33 PM
10/24/21 04:33 PM
tex013
Sydney,Australia
Tex - you work on General Maintenance stuff ? everything that comes in the door . 1910 FN to Toyota Prius . If its a car i fix it . Tex
[Re: superbee69]
#2977958
10/24/21 07:19 PM
10/24/21 07:19 PM
Posts: 6,163 Melbourne , Australia
LA360
If they are anything like Jesel, it will be close to the cost of a new lifter. Jesel replace everything, except the lifter body, not sure if Isky do they same.
Alan Jones
[Re: moparx]
#2978230
10/25/21 01:51 PM
10/25/21 01:51 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
I was quoted around $700 by Isky to rebuild/convert my needle bearing style Red Zones over to the bushed style. That was a couple years ago though. I think it was going to be around $400 to simply rebuild them w/ new needle bearings.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: LA360]
#2978258
10/25/21 02:37 PM
10/25/21 02:37 PM
Posts: 9,112 Rogue River, OR
Jeremiah
Rogue River, OR
If they are anything like Jesel, it will be close to the cost of a new lifter. Jesel replace everything, except the lifter body, not sure if Isky do they same. You can also buy the parts from Jesel to rebuild them yourself. That might have changed.
[Re: fourgearsavoy]
#2978660
10/26/21 04:58 PM
10/26/21 04:58 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I've sent a few sets of bushed lifters in to get rebuilt. Pretty quick and I didn't think the cost was unreasonable but don't remember the cost either.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: CDoering]
#2979725
10/29/21 09:12 PM
10/29/21 09:12 PM
Posts: 23,272 Here
jcc
Here
So what on the bushed lifters is the telltale for the need for rebuild, and use wise, how is that comparing to the needle lifters?
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
