Re: Dash harness I.D. help please
[Re: 6PAX]
#2978364
10/25/21 08:27 PM
10/25/21 08:27 PM
Posts: 43,607 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Closest I can come up with in my 69 parts manual is 2926390 which is a back up lamp switch engine compartment with 383 and 440 w/4-speed up to Nov. 1968. Found 2926381 in the 68 parts manual as instrument panel cluster wiring, can't find that number anywhere else...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2978455
10/26/21 03:51 AM
10/26/21 03:51 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
Green and black wires taped together? That color codes use to be for the speaker
The dash harness PN uses to be around the big bulk of wires close to firewall
An expanded view of the full harness will help for identification
[Re: 6PAX]
#2979122
10/28/21 03:12 AM
10/28/21 03:12 AM
NachoRT74
Valencia, España
Yeap, is violet and is the wires section running to floor dimmer switch, but on the first pic it looks black and just two wires visible lol.
[Re: 70X]
#3018761
02/25/22 10:30 AM
02/25/22 10:30 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
the 68 harness is different than the 69 harness , the difference is a wire on the ignition switch , 69 has it , 68 doesn't ... I think it's a ground ? I've parted a number of 68 and 69 B bodies over the years..
