Dash harness I.D. help please #2978246
10/25/21 02:17 PM
10/25/21 02:17 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
I have a dash wiring harness I want to sell and would like to confirm it's application before I do. When I got it I was told it was from a 68 or 69 B-body non-rally dash application. It has a tag on it with the number 2926380. I don't see any other numbers on it other than what is on the fuse box. If someone could confirm what it is for I would appreciate it.
Re: Dash harness I.D. help please [Re: 6PAX] #2978364
10/25/21 08:27 PM
10/25/21 08:27 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Closest I can come up with in my 69 parts manual is 2926390 which is a back up lamp switch engine compartment with 383 and 440 w/4-speed up to Nov. 1968. Found 2926381 in the 68 parts manual as instrument panel cluster wiring, can't find that number anywhere else... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Dash harness I.D. help please [Re: Rhinodart] #2978455
10/26/21 03:51 AM
10/26/21 03:51 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Green and black wires taped together? That color codes use to be for the speaker
The dash harness PN uses to be around the big bulk of wires close to firewall
An expanded view of the full harness will help for identification
Re: Dash harness I.D. help please [Re: NachoRT74] #2978574
10/26/21 12:41 PM
10/26/21 12:41 PM
Detroit area
Detroit area
It's not for the speaker. There is a red wire along with the black and green going into a plug. The plug is on one end of the harness.
Re: Dash harness I.D. help please [Re: 6PAX] #2978590
10/26/21 01:18 PM
10/26/21 01:18 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I dont think that is a black wire with the green and red.....it looks to be violet, that part of the harness goes to the floor,..its the dimmer switch wiring and connector.
Re: Dash harness I.D. help please [Re: mccannix] #2978701
10/26/21 07:28 PM
10/26/21 07:28 PM
Detroit area
Detroit area
It is violet.
Re: Dash harness I.D. help please [Re: 6PAX] #2979122
10/28/21 03:12 AM
10/28/21 03:12 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Yeap, is violet and is the wires section running to floor dimmer switch, but on the first pic it looks black and just two wires visible lol.
Re: Dash harness I.D. help please [Re: 6PAX] #2979175
10/28/21 09:33 AM
10/28/21 09:33 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I ran that number through my 68 and 69 books and it does not come up. Is there any other numbers on it?
Re: Dash harness I.D. help please [Re: NITROUSN] #3018560
02/24/22 04:52 PM
02/24/22 04:52 PM
Missouri
70X Offline
70X  Offline
Missouri
I have a harness with the same number as well i'm trying to find info on. I was thinking it looks like what you said, a 68 or 69 B Body standard dash harness.
Re: Dash harness I.D. help please [Re: 70X] #3018761
02/25/22 10:30 AM
02/25/22 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the 68 harness is different than the 69 harness , the difference is a wire on the ignition switch , 69 has it , 68 doesn't ... I think it's a ground ? I've parted a number of 68 and 69 B bodies over the years..
