11 3/4 " brake rotors ?
#2976350
10/20/21 03:14 AM
10/20/21 03:14 AM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi where can i get replacement rotors that are a little lighter in weight than a stock one as the ones i have are about 25 bs each . 11 3/4"
just looking to up grade the brakes and maybe loose a few lbs. ? got some new ones 10 1/2/ in and they weighed same as 11 3/4" ones ???? 3750 lb
thank you !
Re: 11 3/4 " brake rotors ?
[Re: calrobb2000]
#2976355
10/20/21 05:07 AM
10/20/21 05:07 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Dr Diff sells them, you might give him a call and ask if he'll weigh one for you. You might have someone with a lathe cut them down a bit too but it would seem a bunch of work for little gain. Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#2976451
10/20/21 12:10 PM
10/20/21 12:10 PM
Posts: 19,587 north of coder
moparx
if all out race car is not in your future, cutting stock rotors is a waste of time and money in my opinion. if better stopping power is your goal, it would be better money spent if one perused the different pad material available, then select what suits your driving style best. just my opinion, your mileage will vary.
[Re: Sniper]
#2976793
10/21/21 12:09 PM
10/21/21 12:09 PM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
Closest your going to find is a set of drilled and slotted ones though not sure the weight savings is much. RockAuto has them. Weight not listed though, 79 Cordoba is the application. Great info here. Thanks! Also, Firm Feel sells really good pads for Mopars. I run them on both my Mopars with the 11 3/4" rotors.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2976975
10/21/21 08:32 PM
10/21/21 08:32 PM
Posts: 10,230 Someplace you aren't
SomeCarGuy
A ‘76 Fury has the 11.75 rotors too. Used to be a good swap, maybe other this are better now? The adapters are hard to find. I thought Andy f was making them though.
I want my fair share
[Re: SomeCarGuy]
#2977001
10/21/21 09:17 PM
10/21/21 09:17 PM
Posts: 31,068 Oregon
AndyF
A ‘76 Fury has the 11.75 rotors too. Used to be a good swap, maybe other this are better now? The adapters are hard to find. I thought Andy f was making them though. Doctor Diff sells the 11.75 adapters
[Re: JohnRR]
#2977886
10/24/21 02:31 PM
10/24/21 02:31 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I received your Email at 2 AM and replied the same day. You weren't up answering emails at 2 am , how dare you sleep ... 3 hour time difference Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2977896
10/24/21 03:51 PM
10/24/21 03:51 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I have 11 3/4 rotors. Got the brackets from DrDiff. No difference in braking. Waste of time and money. Will go back to the 10 1/2 needed.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: 68LAR]
#2978121
10/25/21 09:29 AM
10/25/21 09:29 AM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
I have 11 3/4 rotors. Got the brackets from DrDiff. No difference in braking. Waste of time and money. Will go back to the 10 1/2 needed. There has to be more to it. I made the exact same swap on my porker of a car and it made a fairly noticeable improvement.
