11 3/4 " brake rotors ? #2976350
10/20/21 03:14 AM
10/20/21 03:14 AM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
where can i get replacement rotors that are a little lighter in weight than a stock one as the ones i have are about 25 bs each . 11 3/4"
just looking to up grade the brakes and maybe loose a few lbs. ?
got some new ones 10 1/2/ in and they weighed same as 11 3/4" ones ???? 3750 lb
thank you !
Re: 11 3/4 " brake rotors ? [Re: calrobb2000] #2976355
10/20/21 05:07 AM
10/20/21 05:07 AM
West Palm Beach, Florida
Copper Dart Offline
Copper Dart  Offline
Dr Diff sells them, you might give him a call and ask if he'll weigh one for you. You might have someone with a lathe cut them down a bit too but it would seem a bunch of work for little gain. twocents
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: 11 3/4 " brake rotors ? [Re: Copper Dart] #2976451
10/20/21 12:10 PM
10/20/21 12:10 PM
moparx Offline
moparx  Offline
if all out race car is not in your future, cutting stock rotors is a waste of time and money in my opinion.
if better stopping power is your goal, it would be better money spent if one perused the different pad material available, then select what suits your driving style best.
just my opinion, your mileage will vary.
beer
Re: 11 3/4 " brake rotors ? [Re: moparx] #2976584
10/20/21 06:42 PM
10/20/21 06:42 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Closest your going to find is a set of drilled and slotted ones though not sure the weight savings is much. RockAuto has them. Weight not listed though, 79 Cordoba is the application.
Re: 11 3/4 " brake rotors ? [Re: Sniper] #2976793
10/21/21 12:09 PM
10/21/21 12:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Great info here. Thanks!
Also, Firm Feel sells really good pads for Mopars. I run them on both my Mopars with the 11 3/4" rotors.
Re: 11 3/4 " brake rotors ? [Re: jbc426] #2976975
10/21/21 08:32 PM
10/21/21 08:32 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
A ‘76 Fury has the 11.75 rotors too. Used to be a good swap, maybe other this are better now? The adapters are hard to find. I thought Andy f was making them though.
I want my fair share
Re: 11 3/4 " brake rotors ? [Re: SomeCarGuy] #2977001
10/21/21 09:17 PM
10/21/21 09:17 PM
AndyF Offline
AndyF  Offline
Doctor Diff sells the 11.75 adapters
Re: 11 3/4 " brake rotors ? [Re: Copper Dart] #2977427
10/22/21 10:54 PM
10/22/21 10:54 PM
s. e. pa.
s. e. pa.
dr diff does not answer phone calls !
sent an e mail NO reply !
Re: 11 3/4 " brake rotors ? [Re: calrobb2000] #2977746
10/23/21 10:20 PM
10/23/21 10:20 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I received your Email at 2 AM and replied the same day.
Re: 11 3/4 " brake rotors ? [Re: DoctorDiff] #2977810
10/24/21 10:10 AM
10/24/21 10:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You weren't up answering emails at 2 am , how dare you sleep ...
Re: 11 3/4 " brake rotors ? [Re: JohnRR] #2977873
10/24/21 01:08 PM
10/24/21 01:08 PM
moparx Offline
moparx  Offline
i don't sleep at night............i'm a vampire............. devil whistling biggrin
beer
Re: 11 3/4 " brake rotors ? [Re: JohnRR] #2977886
10/24/21 02:31 PM
10/24/21 02:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
3 hour time difference shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: 11 3/4 " brake rotors ? [Re: fourgearsavoy] #2977896
10/24/21 03:51 PM
10/24/21 03:51 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I have 11 3/4 rotors. Got the brackets from DrDiff. No difference in braking. Waste of time and money. Will go back to the 10 1/2 needed.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 11 3/4 " brake rotors ? [Re: 68LAR] #2978061
10/25/21 03:03 AM
10/25/21 03:03 AM
s. e. pa.
s. e. pa.
yea ;
i have a cuda power brake and a valiant non power disc and i like the pedal feel on both better than the 11 3/4 belvedere so far .
cuda 3650 lb val 3250 lb both stop good .
maybe i need to change mc from 15/16 ? works like power brake just a little more pedal movement than i like .
Re: 11 3/4 " brake rotors ? [Re: 68LAR] #2978121
10/25/21 09:29 AM
10/25/21 09:29 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
There has to be more to it. I made the exact same swap on my porker of a car and it made a fairly noticeable improvement.
