70 ROADRUNNER/GTX INTERIOR QUESTION #297787
04/23/09 08:35 PM
04/23/09 08:35 PM
Virginia
V
vadartlover Offline OP
V
Virginia
Did the 70 RR/GTXs ALL have rear arm rests or were they options? Any good leads for repro arm rests if this is the case??
Re: 70 ROADRUNNER/GTX INTERIOR QUESTION [Re: vadartlover] #297788
04/23/09 11:37 PM
04/23/09 11:37 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes.
GTX - brite base standard
RR- color base standard on Coupe, bright bases with optional Decor package. Bright base standard with HT.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
