Any modern / current Mopar techs here #2977553
10/23/21 11:46 AM
10/23/21 11:46 AM
It's a dry heat
gtx6970 Online content OP
gtx6970  Online Content OP
It's a dry heat
On my recently purchased 2012 Ram 1500 sport .
it had an aftermkt radio in it I hate. I have what I can only assume is the original OEM radio for this truck that was laying on the back seat . I went to re-install it and have no sound, ( all other functions seem to work as designed )
I have no desire to go to any kind of aftermkt . and would much prefer the stock. Problem is,,,I cant find the exact same number radio.
I have a few ' SIMILAR ' radios bookmarked on ebay that the sellers SAY will work . But I want to be sure. AND Ive read some require a code to operate , is this true on all OEM radios from this period .
Re: Any modern / current Mopar techs here [Re: gtx6970] #2977565
10/23/21 12:44 PM
10/23/21 12:44 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill I would "assume" that a code is required but the fact that you have other functions makes me think maybe not? My '95 E320 requires a code like when the battery is disconnected (or goes dead blush ) but at that point nothing functions until you put in the code. I think with your VIN and a call to your local RAM dealer they can tell you if it needs a code and what your code is. On the other hand I wonder if the lack of audio is the reason for the replacement radio??
Mike
Re: Any modern / current Mopar techs here [Re: A12] #2977571
10/23/21 12:59 PM
10/23/21 12:59 PM
It's a dry heat
It's a dry heat
Mike,
I got the supposed code the dealer said I needed.
They told me there would be a prompt when the radio powers up the screen will display 'CODE' and then I need to enter said code. Yet I get no such prompt. Ive read online not all OEM radios require such code to operate
The radio turns on , I have clock functions , all presets work , all the knobs work stations change , etc etc. The only noise I get is an occasional light 'thump ' sound.
There are several radios on ebay avail of various pt numbers and features .
I have no issues upgrading to a slightly different radio ,,,,,provided it will work as designed
PS,,,,,I just bought the truck this past August so I have no idea WHY the radio was replaced. Yet seems odd they would have kept it , if the reason it was removed in the 1st place was if it didnt work
Re: Any modern / current Mopar techs here [Re: gtx6970] #2977583
10/23/21 01:50 PM
10/23/21 01:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's possible that when the aftermarket radio was installed, the speakers were also changed and those speakers are incompatible with the factory radio. If you have a shop near you that specializes in audio, maybe they can help.
Re: Any modern / current Mopar techs here [Re: John_Kunkel] #2977589
10/23/21 02:11 PM
10/23/21 02:11 PM
It's a dry heat
It's a dry heat
Hmmmmm,
never thought of that
Re: Any modern / current Mopar techs here [Re: gtx6970] #2977693
10/23/21 07:15 PM
10/23/21 07:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I replaced ALL the speakers & added 2 sub woofers to the stock radio in my 2020 T/A 392, no problems
Re: Any modern / current Mopar techs here [Re: CSK] #2977718
10/23/21 08:52 PM
10/23/21 08:52 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Seems like rams of this age2009-2013 had probems with a soldered connection for sound.in the radio, and has to be resoldered.Check on you tube on how to do it.
Re: Any modern / current Mopar techs here [Re: GarageDodge] #2977732
10/23/21 09:50 PM
10/23/21 09:50 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Okay Bill it's time to buy one of these small heat guns like in this YouTube video and start a new car audio repair hobby laugh2
Re: Any modern / current Mopar techs here [Re: A12] #2977733
10/23/21 09:52 PM
10/23/21 09:52 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Bill in the YouTube video he states he has audio for the CD player, is that the case for you?
Re: Any modern / current Mopar techs here [Re: A12] #2977866
10/24/21 12:48 PM
10/24/21 12:48 PM
It's a dry heat
It's a dry heat
Mike
To be honest. I dont know. It never even entered my mind to try it that way
Radio is out and dropped off at a friends. He is an electrical engineer. and Ive already forwarded him the link above. and he already has it apart .
I should have it back next weekend and have my fingers crossed this repairs it
Bill
Re: Any modern / current Mopar techs here [Re: gtx6970] #2983296
11/09/21 12:09 AM
11/09/21 12:09 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Hi Bill just curious if your guy had any luck with your radio?
Mike
Re: Any modern / current Mopar techs here [Re: A12] #2983533
11/09/21 05:13 PM
11/09/21 05:13 PM
It's a dry heat
It's a dry heat
Mike
Got it back a few weeks ago.
Sorry to report........Still no worky.
Im on the hunt for a replacement.
Re: Any modern / current Mopar techs here [Re: gtx6970] #2983551
11/09/21 05:52 PM
11/09/21 05:52 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
This is just a shot in the dark, but some aftermarket radios have a way to switch their output depending on whether or not it's being used with an amplifier. If it's set to use an amp and you don't have one, there'll be very little or no sound. Is there a mystery switch or button somewhere on the radio?
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Any modern / current Mopar techs here [Re: 3hundred] #2983578
11/09/21 06:49 PM
11/09/21 06:49 PM
It's a dry heat
It's a dry heat
Nope.
I was told he thinks internal amp is dead. Or something on the board itself.
With no real parts list or schematic of the internals.
It was a shot in the dark.
So nothing ventured....nothing gained.
Re: Any modern / current Mopar techs here [Re: gtx6970] #2983642
11/09/21 09:14 PM
11/09/21 09:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Have the dealer run your VIN. Ask for the options it was built with. The radio will have a three digit code like RHB. That is what you will look for as a compatible radio to your truck. It still may need to be unlocked. A lot of sellers have then unlocked and ready to go.
