My torque converter snout measures 1.8.06 that inside diameter of my crankshaft measures 1.8 14 when I put the converter up in the crankshaft just to check it out it has a little bit of up and down play is that going to eat the bushing out of my transmission because most snouts on a converter usually measure one point 810 any advice would be greatly appreciated
Install the flex plate to converter bolts and see how much movement you have.
Obviously leave the bolts loose when checking.
All Mopar RWD converters are supposed to be bottomed out in the back of the crank.
