Torque converter to crankshaft clearance #2977737
10/23/21 10:07 PM
10/23/21 10:07 PM
Kentucky
71blackdemon Offline OP
Kentucky
My torque converter snout measures 1.8.06 that inside diameter of my crankshaft measures 1.8 14 when I put the converter up in the crankshaft just to check it out it has a little bit of up and down play is that going to eat the bushing out of my transmission because most snouts on a converter usually measure one point 810 any advice would be greatly appreciated
Re: Torque converter to crankshaft clearance [Re: 71blackdemon] #2977755
10/23/21 11:06 PM
10/23/21 11:06 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Anything over .005 should be corrected.
Re: Torque converter to crankshaft clearance [Re: rickraw] #2977759
10/23/21 11:34 PM
10/23/21 11:34 PM
Kentucky
Kentucky
Mine is probably .008 but I have no way to correct it
Re: Torque converter to crankshaft clearance [Re: 71blackdemon] #2977765
10/24/21 12:20 AM
10/24/21 12:20 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
You could get it welded then machined to the correct diameter.
Re: Torque converter to crankshaft clearance [Re: 71blackdemon] #2977767
10/24/21 12:27 AM
10/24/21 12:27 AM
A727Tflite Offline
A727Tflite  Offline
Install the flex plate to converter bolts and see how much movement you have.
Obviously leave the bolts loose when checking.
All Mopar RWD converters are supposed to be bottomed out in the back of the crank.
