Re: Carter Fuel Pump HELP!!
[Re: lewtot184]
#2977347
10/22/21 07:06 PM
10/22/21 07:06 PM
Posts: 1,381 VA
dragon slayer
VA
It is a pulse damper to assist the air dome diaphragm from collapsing too much on the pressure stroke. Not all pumps have it. When you say leak, what type of leak? Internal into the isolated chamber or external to the pump.
[Re: dragon slayer]
#2977674
10/23/21 06:12 PM
10/23/21 06:12 PM
Posts: 743 New York
R/T1968R/T
New York
All surfaces look good. Should that middle area be machined? It looks as cast. I think gas spilled into that chamber when it was disassembled.
[Re: lewtot184]
#2977804
10/24/21 09:50 AM
10/24/21 09:50 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2977833
10/24/21 11:16 AM
10/24/21 11:16 AM
Posts: 3,916 usa
lewtot184
usa
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me.
[Re: lewtot184]
#2978132
10/25/21 09:56 AM
10/25/21 09:56 AM
Posts: 1,381 VA
dragon slayer
VA
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me. If you are dealing with original fp from the 60s and early 70s you won't see that foam. Later version and the 6903/4862 you will, but not always.
[Re: dragon slayer]
#2978157
10/25/21 11:44 AM
10/25/21 11:44 AM
Posts: 3,916 usa
lewtot184
usa
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me. If you are dealing with original fp from the 60s and early 70s you won't see that foam. Later version and the 6903/4862 you will, but not always. factory 2 valve pumps don't have the chamber so a sponge couldn't be installed.
[Re: dragon slayer]
#2978274
10/25/21 03:50 PM
10/25/21 03:50 PM
Posts: 3,916 usa
lewtot184
usa
Of course. I am talking about rebuild able pumps. 4024, the 2500 series, even very early 6903. Plus the marine pumps. I have disassembled and documented many of the Carter orig pumps. Cast number, part numbers, orientation, volume, spring pressures etc... what are the spring pressures?
