Re: Carter Fuel Pump HELP!!
[Re: lewtot184]
#2977347
10/22/21 07:06 PM
10/22/21 07:06 PM
Posts: 1,321 VA
dragon slayer
VA
It is a pulse damper to assist the air dome diaphragm from collapsing too much on the pressure stroke. Not all pumps have it. When you say leak, what type of leak? Internal into the isolated chamber or external to the pump.
[Re: dragon slayer]
#2977674
10/23/21 06:12 PM
10/23/21 06:12 PM
Posts: 734 New York
R/T1968R/T
New York
All surfaces look good. Should that middle area be machined? It looks as cast. I think gas spilled into that chamber when it was disassembled.
[Re: lewtot184]
#2977804
10/24/21 09:50 AM
10/24/21 09:50 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2977833
10/24/21 11:16 AM
10/24/21 11:16 AM
Posts: 3,916 usa
lewtot184
usa
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me.
[Re: lewtot184]
#2978132
10/25/21 09:56 AM
10/25/21 09:56 AM
Posts: 1,321 VA
dragon slayer
VA
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me. If you are dealing with original fp from the 60s and early 70s you won't see that foam. Later version and the 6903/4862 you will, but not always.
[Re: dragon slayer]
#2978157
10/25/21 11:44 AM
10/25/21 11:44 AM
Posts: 3,916 usa
lewtot184
usa
I was going to post this same question about the sponge. Since not all pumps have it, is there a downside or advantage to leaving it out? all carter 3 valve pumps i've messed with have the sponge. i take my pumps apart and re-work them and don't put the sponge back in with no adverse effects. i say keep it if you want, remove it if you don't; hasn't made any issues one way or the other for me. If you are dealing with original fp from the 60s and early 70s you won't see that foam. Later version and the 6903/4862 you will, but not always. factory 2 valve pumps don't have the chamber so a sponge couldn't be installed.
[Re: dragon slayer]
#2978274
10/25/21 03:50 PM
10/25/21 03:50 PM
Posts: 3,916 usa
lewtot184
usa
Of course. I am talking about rebuild able pumps. 4024, the 2500 series, even very early 6903. Plus the marine pumps. I have disassembled and documented many of the Carter orig pumps. Cast number, part numbers, orientation, volume, spring pressures etc... what are the spring pressures?
[Re: dragon slayer]
#2978467
10/26/21 07:05 AM
10/26/21 07:05 AM
poboyengineering
pennsylvania
Do you have this info for the 6270 small block pump?
#2978499
10/26/21 09:27 AM
10/26/21 09:27 AM
Posts: 1,321 VA
dragon slayer
VA
Top: MO-3032 12 (Bulge and multi holes) Middle: M80-730 R 8 C Round shaped cavity OD 3.5”, ID 2 9/16” Hole ring dia 3 1/16” 1/4" NPT Bottom: M118-276 3 C R (Different Design no boss C R/90 Clocking/Course Thread) Modified opening Lever: 177-381 Lever Spring Gray 1.55”L x .390” Dia Diaphm: None 364 Stud 2.20” OL stud, 8 hole 3 5/8” OD, 2 3/16” Lower Disc, 2 3/16” Upper Disc, Steel Spring
This was a pump with no date code, but the later manufacture with bulge on Top that marine pumps would have a vent installed. The Bottom was modified outlet to accept larger fitting by previous owner.
I did not cut off rivet to release spring and measure it.
The other portion of the diaphragm that effects volume and pressure of the pump is those steel disc that sandwich the rubber diaphragm. They are actually different diameters on original pumps depending on the model. They also have stamped ridge that had a patent by orig carter. If you think of the captured volume of fuel in the pump outlet chamber under the diaphragm when pulled up fully the size of that washer determines how much outside area of the diaphragm can actually stretch, tapered volume and what is solid surface for the built up fuel pressure to resist the downward push of the spring. I have post picture of chamber before, here they are again. Notice gear shaped hemi chamber which increases volume under diagram per stroke, which also would lower pressure required to stop stroke when carb needle closed. Hence the larger spring force to compensate. I also have seen orig hemi with extra washers under the stud to increase preload of that specific spring. Also notice the bottom of the hemi pump does not have to have inlet fuel flow through a casting to get to chamber. The inlet fitting opens directly into the inlet chamber.
The round chamber is the typical 6903/4862/6270 modern pump parts.
