Page 3 of 5 1 2 3 4 5
Re: roll bar in a street car? [Re: cudaman1969] #2977073
10/22/21 12:33 AM
10/22/21 12:33 AM
AndyF Offline
AndyF  Offline
Originally Posted by cudaman1969
Like I said, you can bolt it in, look at the rule book. 6” square plate bolted to floor for the hoop, down bars bolted at floor and hoop, side bars swing out that’s bolted. Problem solved till you go 9.99 then you have a race car, period.
Depends on the tech guy and the track. Typically they'll allow the plate to be bolted to the floor but they often won't allow the down tubes to be bolted to the main hoop. If you weld the down tubes to the main hoop to pass tech then you can't remove the roll bar from the cage. I've had a couple of different buddies get busted on this exact thing. They were told that a bolt together roll bar was legal but the get the track and the tech guy says it has to be welded together.
Re: roll bar in a street car? [Re: plycuda] #2977109
10/22/21 06:59 AM
10/22/21 06:59 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Originally Posted by plycuda
I have had both and like some said its nice not to be in the way. if you want to actually want to use the back seat how do they get in it. the cage if fine long as there only 2 of you.
Crawl over the bar. Heck I can still do it. Turned 67 last Sunday.
Doug
Re: roll bar in a street car? [Re: dvw] #2977112
10/22/21 07:14 AM
10/22/21 07:14 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I guess you guys crying about safety and a roll bar in the passenger compartment have never ridden in a Jeep?!
'63 Dodge 330
11.19 @ 121 mph
Re: roll bar in a street car? [Re: W.I.N. Racing] #2977120
10/22/21 07:44 AM
10/22/21 07:44 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted by W.I.N. racing
Originally Posted by gregcharger72
Do any of you get away with running mid 10 second passes at the drag strip with out a roll bar? my car is primarily a street car that i take to the track a couple times a year. what are your thoughts about roll bars in street cars. I see there are several newer challengers that are that fast and faster and are not required to have roll bars.
"get away with" is purely at the tracks discretion, neither NHRA or IHRA would condone it as it violates their Rules and has potential to effect their liability and insurability (track and sanctioning body). And to answer your question, at my local track I have seen an occasionally on the first never on the second pass. The sanctioning bodies are very concerned with chassis/roll bar with this type of infraction.
I see a lot of late models without them running well below the 11.50 requirement. Not sure how that works. Let alone have a diaper on them.
Re: roll bar in a street car? [Re: AndyF] #2977133
10/22/21 08:35 AM
10/22/21 08:35 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I see the part in the rules where it says the rear down bars have to be welded to the hoop.
What I don't see is anything saying they must be one continuous piece of tubing. Make it bolt together say a foot from the hoop and carry the rule book with you. Done right it may be the strongest part of the cage. For sure it will be stronger than front swing out bars.
Re: roll bar in a street car? [Re: GomangoCuda] #2977141
10/22/21 09:11 AM
10/22/21 09:11 AM
GomangoCuda Offline
GomangoCuda  Offline
Things sure have changed. Fifty years ago this was legal and everybody used them
Re: roll bar in a street car? [Re: Hemi_Jack] #2977144
10/22/21 09:25 AM
10/22/21 09:25 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted by Hemi_Jack
This is taken from the 2021 NHRA rule book general regulations. It looks like the cross bars and rear bars definitely need to be welded to the main hoop. Be tough to get it in and out of the car if bolted to the plates on the floor.
4:10 ROLL BAR
All roll bars must be within 6 inches of the rear, or side, of the
driver’s head, extend in height at least 3 inches above the
driver’s helmet with driver in normal driving position or be within
1 inch of the roof/headliner in the area above the driver’s helmet,
and be at least as wide as the driver’s shoulders or within 1 inch
of the driver’s door. Roll bar must be adequately supported or
cross-braced to prevent forward or lateral collapse. Rear braces
must be of the same diameter and wall thickness as the roll bar
and intersect with the roll bar at a point not more than 5 inches
from the top of the roll bar. Crossbar and rear braces must be
welded to main hoop. Sidebar must be included on driver’s
side and must pass the driver at a point midway between the
shoulder and elbow. Swing-out sidebar permitted. All roll bars
must have in their construction a cross bar for seat bracing
and as the shoulder harness attachment point; cross bar must
be installed no more than 4 inches below, and not above, the
driver’s shoulders or to side bar. All vehicles with OEM frame
must have roll bar welded or bolted to frame; installation of
frame connectors on unibody cars does not constitute a frame;
therefore it is not necessary to have the roll bar attached to the
frame. Unibody cars with stock floor and firewall (wheeltubs
permitted) may attach roll bar with 6-inch x 6-inch x .125-inch
steel plates on top and bottom of floor bolted together with
at least four 3/8-inch bolts and nuts, or weld main hoop to
rocker sill area with .125-inch reinforcing plates, with plates
welded completely. Also, the roll bar may be welded to frame
connectors that are fully welded in place and are 1 5/8 inches
x .118-inch MS or .083-inch CM round and/or 2 inch x 2 inch
x .058 MS or CM rectangular. All 4130 chromoly tube welding
must be done by approved TIG heliarc process; mild steel
welding must be done by approved MIG wire feed or approved
TIG heliarc process. Welding must be free of slag and porosity.
6” max
All cars with an OEM frame must
have roll bar attached to frame.
Cars without frame use 6” square
1/8” steel plates on top and
bottom of floor, securely bolted
together with at least four 3/8”
bolts, or top plate welded to
rocker sill.
All materials must be 1 3/4” O.D. x .118” mild steel or .083”
4130 chromoly tubing, except A, which is
1 1/4” O.D. x .118” mild steel or .065” 4130 chromoly tubing.
5” max
4:10
Maximum of 6”
from roll bar to
driver’s helmet.
Maximum of 5”
from top of roll
bar to brace.
Section 21, page 22 General Regulations
Any grinding of welds prohibited. See illustration. Roll bar must
be padded anywhere driver’s helmet may contact it while in
driving position. Adequate padding must have minimum 1/4-
inch compression or meet SFI Spec 45.1. All cars running 9.99
(*6.39) or quicker, SFI Spec 45.1 mandatory.
Yes tube must be welded to hoop just like the side bar, the attachments. It’s all in the wording, bolt it down about 6-8” from the weld. Make-female type connector with two grade 8 bolts opposite. NHRA Tech guy said ALL they can inspect-pass is having proper bars in the right place not how bad the welds are.
Re: roll bar in a street car? [Re: cudaman1969] #2977180
10/22/21 11:06 AM
10/22/21 11:06 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Another question: I haven't installed my subframe connectors yet. If I put in a 6-pt. roll bar, are the connectors still useful? work
Re: roll bar in a street car? [Re: GY3] #2977186
10/22/21 11:16 AM
10/22/21 11:16 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
To be fair though, the cages in Jeeps and Broncos and other similar offroad vehicles are much further away from your head than a rollbar in a passenger car, and are also padded in the critical spots.
That being said, I've had a rollbar in a fox mustang before though and I never really worried about it. It's just a risk I'm willing to accept. I may eventually put a 6pt bar in my Fury but for now I haul enough people around in it that I don't want them to have to climb around the bars to get to the backseat.
Re: roll bar in a street car? [Re: Blusmbl] #2977196
10/22/21 11:32 AM
10/22/21 11:32 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
My CJ5 doesn't have padding. It is from 1980, though, long before everyone thought they had to have all the safety features in their driving appliances.
'63 Dodge 330
11.19 @ 121 mph
Re: roll bar in a street car? [Re: DrCharles] #2977200
10/22/21 11:34 AM
10/22/21 11:34 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Absolutely! They make a world of difference in a uni-body car!
'63 Dodge 330
11.19 @ 121 mph
Re: roll bar in a street car? [Re: GY3] #2977230
10/22/21 12:49 PM
10/22/21 12:49 PM
iagree Make several(4+ each side up) 1/2 or bigger holes in each side of the sub frames to weld them to the sub frames, not just where they slide into the sub frames in the rear weld
Re: roll bar in a street car? [Re: Cab_Burge] #2977249
10/22/21 01:33 PM
10/22/21 01:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
These questions pop up fairly often and the answers are always the same. Everything is in the rulebook or the SFI spec. Other than some amendments to some of the specs, it hasn't changed in many years. Not wanting to do it doesn't change the answers. Not wanting to cut or "mess up" a nice car also does not change the answers.
It needs to be welded in or welded to proper plates on the floor and 100% welded together, except for legal swing out side bars, which have their own requirements. They still allow plates to be bolted to the floor, but I haven't seen that done by anyone in a long time. The diagonal "D" bars from the mainhoop to the floor are required if it's not welded to a frame, also on plates or welded to frame ties. Chicken s*** welds done with a fluxcore or stick welder will fail a cert.
If a track allows anything other than this to slide, it's between the "tech" guy, the track owner and his insurance company, if he has insurance. You can run there if you like. I have in the past and saw people get hurt over some dumba$$ stuff.
Years ago, we got involved with an old truck with a big motor that needed a cage before they would let him come back. He didn't want the body cut. I had similar conversations with one of the best guys at NHRA about it. He finally got tired of me asking, "well what if" and said "does he want a street car or a race car? If he wants to do that, it has to be this way." I never asked again.
Keep in mind, the rule book is a minimum. There is plenty of room for additional things to be done to improve the structure.
Re: roll bar in a street car? [Re: CMcAllister] #2977257
10/22/21 01:59 PM
10/22/21 01:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
We had a guy at our track a few years back with an import that had a 4 point bar, seat not securely mounted, etc. He was running deep into the 9's as I recall but claimed to be much slower when teched.
He ended up hitting the guardrail broadside on the first return road entrance when he lost control (worst possible place) and it killed him.
The NHRA paid out (like they always do when there is a death) and fortunately, the family and in specific the father knew what the son was doing and knew it was only a matter of time and chose not to sue (rare in this day and age).
All it takes is one accident like this with sue happy next of kin to permanently shut down a track.
'63 Dodge 330
11.19 @ 121 mph
Re: roll bar in a street car? [Re: gregcharger72] #2977263
10/22/21 02:18 PM
10/22/21 02:18 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"frame connectors that are fully welded in place and are 1 5/8 inches x .118-inch MS or .083-inch CM round and/or 2 inch x 2 inch x .058 MS or CM rectangular"
I don't understand this. The connector provides vertical bending resistance.
The 2" rectangular is much stiffer than the 1-5/8" tube.
I fail to see the engineering that requires the rear tube to be welded to the hoop. A bolt-together design might be more expensive, complex, and heavy but easily made stronger than a weld. One method would be a flange-to-tube section welded to each of the main and rear, with a removable flanged tube between them. The attachment to both tubes passes already, and the shear strength at the flanges can be met by sizing the bolt area.
The welded area is the contact surface is (OD + ID ÷ 2) of the smaller tube × Pi × wall thickness. A 1-3/4" × .120" tube welded seam is .614 sq. in. 4 × 1/2" bolts provide .785".
Please: I'm OLD! Correct my errors, please.
Boffin Emeritus
Re: roll bar in a street car? [Re: GY3] #2977267
10/22/21 02:27 PM
10/22/21 02:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I like it, I had 73 CJ5
Re: roll bar in a street car? [Re: cudaman1969] #2977273
10/22/21 02:57 PM
10/22/21 02:57 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
It's really irrelevant who owned what jeep here IMO, its more pertinent who survived a hard crash in one, without any headrests it would be amazing if they retained movement below one's neck.
I have a lengthy history of injury free driving with limited safety measures in place over many decades, only real conclusion I can draw with certainty, I was at least lucky.
Re: roll bar in a street car? [Re: polyspheric] #2977278
10/22/21 03:07 PM
10/22/21 03:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Explain that to the NHRA and let us know how it works out.
Re: roll bar in a street car? [Re: GomangoCuda] #2977284
10/22/21 03:21 PM
10/22/21 03:21 PM
AndyF Offline
AndyF  Offline
That might work at some tracks but it won't work at all of them. One of the EFI cars that I tune got bounced because the rear down bars were bolted together. He had to get them welded before the car would pass tech. His local track allowed him to run but as soon as he started towing to out of town races he got put on the trailer.
Re: roll bar in a street car? [Re: polyspheric] #2977287
10/22/21 03:28 PM
10/22/21 03:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Maybe not an an error, but an omission, FC's also supply resistance to compression, tension, and twist, and depending on cross section/thickness chosen each of the the four resistances mentioned here vary as needed for the application. Meaning to me, a 3x3 tube might really best all round solution, but seldom seen.
