Indy 3X , 550 cubes, gains from p porting the intake?
#2976772
10/21/21 11:02 AM
10/21/21 11:02 AM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My 550 cu in motor with 15-1 compression, .870 lift roller on methanol has the 3X Indy intake. Anyone have a 3X ported? Gains? I have port injection.
Re: Indy 3X , 550 cubes, gains from p porting the intake?
[Re: gregsdart]
#2976778
10/21/21 11:26 AM
10/21/21 11:26 AM
Posts: 10,049 MN
JERICOGTX
MN
Have you ran it on the dyno yet?
69 GTX
68 Road Runner
[Re: Dragula]
#2976888
10/21/21 04:37 PM
10/21/21 04:37 PM
gregsdart
On my 512 I gained over .12s and at least +1mph from removing that damn clover shape out of the top of the 4500 intake. I just called Wilson manifolds and it sounds like they would do a similar reshaping on mine. It won't be cheap if I have them work on it but I have spent more$$$$ for a shot at less power gain.
[Re: gregsdart]
#2977136
10/22/21 09:03 AM
10/22/21 09:03 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
On my 512 I gained over .12s and at least +1mph from removing that damn clover shape out of the top of the 4500 intake. I just called Wilson manifolds and it sounds like they would do a similar reshaping on mine. It won't be cheap if I have them work on it but I have spent more$$$$ for a shot at less power gain. There's probably 25 or so HP in porting it TO YOUR APPLICATION. But again because it isn't a wet application I don't feel that is hard to do for ANYONE who knows what their doing. There may be something obvious in the plenum. Pipemax will give you ideal intake track length #'s. I believe the power you got off the dyno..where does that put you in your 3050lbs? I think you're not using all you have. Just trying to sae you some unnecessary money.
[Re: HardcoreB]
#2977152
10/22/21 10:02 AM
10/22/21 10:02 AM
gregsdart
On my 512 I gained over .12s and at least +1mph from removing that damn clover shape out of the top of the 4500 intake. I just called Wilson manifolds and it sounds like they would do a similar reshaping on mine. It won't be cheap if I have them work on it but I have spent more$$$$ for a shot at less power gain. There's probably 25 or so HP in porting it TO YOUR APPLICATION. But again because it isn't a wet application I don't feel that is hard to do for ANYONE who knows what their doing. There may be something obvious in the plenum. Pipemax will give you ideal intake track length #'s. I believe the power you got off the dyno..where does that put you in your 3050lbs? I think you're not using all you have. Just trying to sae you some unnecessary money. The last runs I made were at 3015 lbs, went 154 mph at 8.84. BUT, I had some serious issues. The trans was hurting, found a bad wobble. At passenger side front. Now I know why the acceleration graph looks like it does😟
[Re: gregsdart]
#2977768
10/24/21 01:09 AM
10/24/21 01:09 AM
Posts: 43,300 Bend,OR USA
Cab_Burge
Is this intake a early 440-3 or the later one with the single cast in boss for the EFI injectors? There is a distinct difference in the two on the intake runner divider length sticking into the plenum ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I think the later manifolds stick in further than the original ones with the two cast in individual bosses for the EFI injectors ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Your picture looks like the original shorter dividers clean up a little ![confused confused](/ubbthreads/images/graemlins/custom/confused.gif)
[Re: Wicked49670dart]
#2977839
10/24/21 11:36 AM
10/24/21 11:36 AM
fast68plymouth
So. Burlington, Vt.
Looks like Gregs manifold has been relieved around the throttle bores a bit. Perhaps to accommodate a carb with slightly larger than “standard”(2”) 4500 throttle bores.
If Greg is running a throttle body with one large bore(like a flying toilet), I feel like the cloverleaf stuff should def go. Although, with the plenum area being dry, it may not amount to much of anything.
[Re: Cab_Burge]
#2977843
10/24/21 11:45 AM
10/24/21 11:45 AM
Posts: 16,932 NC
440Jim
NC
Is this intake a early 440-3 or the later one with the single cast in boss for the EFI injectors? I believe Greg is using a -3X manifold, not the -3 I know the -3X is a lot taller (see Indy catalog), but I don't know if the plenum to runner area is larger in cross section.
[Re: Cab_Burge]
#2977978
10/24/21 08:03 PM
10/24/21 08:03 PM
gregsdart
Is this intake a early 440-3 or the later one with the single cast in boss for the EFI injectors? There is a distinct difference in the two on the intake runner divider length sticking into the plenum ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I think the later manifolds stick in further than the original ones with the two cast in individual bosses for the EFI injectors ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Your picture looks like the original shorter dividers clean up a little My 3X has vertical injecters bosses. I bought it in Jan of 2003. Looks like i did some whittling for the four Terminater 2.5 inch throttle blades.
