Re: 1200 Horsepower options?
[Re: Mr PotatoHead]
#2976995
10/21/21 09:12 PM
10/21/21 09:12 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
They are saying 16-17k on the ZZ632 Think that article said the 572 was that price, not the 632, which they didn't have a price on, as i recall, just speculation
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2977004
10/21/21 09:20 PM
10/21/21 09:20 PM
Posts: 9,432 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Thanks for the correction.
The few things ive read said in the neighborhood of. Whats neighborhood mean, 17, 18k? Should be interesting.
The Detroit automaker did not offer a price to go along with this impressive new beast of a motor, but a new 572 with 727 horsepower typically costs around $16,000. Expect the price for this new 632 to be in that neighborhood. And start thinking of places to stick it.
STOP POTATO HATE!
[Re: Mpetros]
#2977021
10/21/21 09:40 PM
10/21/21 09:40 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks Can probably be done or close to it, but with a well massaged modified cast single-4 intake converted for EFI, very very good set of heads/all other parts combo, and in the hands of the right engine builder who has a warehouse for you to fill it with enough cash! Call Best Machine, Book Racing, Buck, Uratchko, BES or even Brett Miller could get down with it if he wanted to.
"Any fool can know. The point is to understand"
- A. Einstein
[Re: Mpetros]
#2977039
10/21/21 10:15 PM
10/21/21 10:15 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks With or without a power adder?
[Re: Mpetros]
#2977165
10/22/21 10:31 AM
10/22/21 10:31 AM
Posts: 4,669 Wichita
GY3
Wichita
As bad as I hate to say it, BBC is probably going to be the most reasonable option.
It's going to be expensive to begin with but you will easily take the Chevy price and double it for anything Mopar at this level.
[Re: camastomcat]
#2977217
10/22/21 12:20 PM
10/22/21 12:20 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
It can be done if your pockets are deep enough and you are willing to go there and have time to spend waiting for it to get done.
As for the Chevy engine it is a new cylinder head, symetrical spread port deal. It wont be coming in anywhere near $16-17k
[Re: Mpetros]
#2977244
10/22/21 01:23 PM
10/22/21 01:23 PM
Posts: 4,206 New York
polyspheric
New York
This is well inside the bracket of "if the purpose is to go fast, boost is the best value per dollar spent".
Boffin Emeritus
[Re: Al_Alguire]
#2977286
10/22/21 03:28 PM
10/22/21 03:28 PM
Posts: 30,995 Oregon
AndyF
As for the Chevy engine it is a new cylinder head, symetrical spread port deal. It wont be coming in anywhere near $16-17k My guess on the new ZZ632 price is $28,000 but that is just a guess based on where the market for 1000 hp BBC crate motors is. Some of it depends on if the EFI system is complete with controller, injectors and throttle body or if it is just a bare intake manifold. The EFI system alone will add another $5000 to the bill. Shafiroff sells a 632 twisted 20 crate engine that makes 1000 hp for $22,000. By the time you put some good parts on it the price goes up a few thousand but it is still a good deal compared to asking the machine shop at the local NAPA to build you a 1000 hp engine. https://www.shafiroff.com/chevy-pump-gas-engine/632-bigdawg-twisted-sr20.php
[Re: birdtracker]
#2977360
10/22/21 07:58 PM
10/22/21 07:58 PM
Posts: 4,673 On the parachute mount
n20mstr
Best machine has built 1200+ Hp BB mopar 632 BES has built B1 engines that have made almost 1100 , one carb . I’m sure BES or Best Machine can build a Predator head engine that could make 1200. Does it have to be carb ? Fuel inj probably a better option because you can use 2200cfm throttle body IF price is important….. don’t build a BB mopar , GM is a lot cheaper
....BAD A$$ STREET CAR.....
[Re: Mpetros]
#2977458
10/23/21 02:46 AM
10/23/21 02:46 AM
Cab_Burge
I'm hoping to build my next all out drag race BB wedge motor next year with a 4.500 bore Koleno high nickel block and use a old 4.375 stroke Sonny Bryant top fuel crank with full counterweights. I'll use a set of B1-MC heads with a sheet metal 2x4 tunnel ram intake but I may try the cast single four barrel intake with a single1050 CFM Holley Dominator first along with maybe testing E85 as fuel on the single carb deal I'm shooting for 1000 HP+ with the single four set up on race gas and 1100+HP on the 2x4 barrel set up on the best sheet metal tunnel ram intake, I have two of those intakes to test
[Re: A/MP]
#2977971
10/24/21 07:44 PM
10/24/21 07:44 PM
AndyF
I think this is a good indicator that the end of the Mopar SB and BB are on the last leg. How often do you see a non hemi Mopar winning at the track or street when the HP requirements are over 1200-1500. Thank God we have a strong foothold on the nostalgia classes, Mopar days and stock eliminator. Yeah I was very surprised to see GM introduce a 1000 hp crate engine. That is crazy but also kind of cool. If those engines are available and the price is fair then you'll start to see a lot of them show up at the track. Mopar Performance could've introduced a 1000 hp big block crate engine years ago when had the blocks but I don't think there was anyone left at MP in those days who had the guts to make a project like that happen. It could've been done but it would've required breaking some of MP's old rules about which kind of parts to use.
[Re: EchoSixMike]
#2978031
10/24/21 10:14 PM
10/24/21 10:14 PM
Al_Alguire
Las Vegas
99 Hemi and be done. Would have to make a "cast" intake but HP goal would be met and exceeded.
[Re: Mpetros]
#2978104
10/25/21 07:32 AM
10/25/21 07:32 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks Mopar has some nice choices at the 1000hp level, not so much at +1200hp level. That's going to be more of a one off, but it can be done. Me, I like the moved Center Line, 4.84 bore space 655 Millenium Hemi that Best Machine did a couple years ago. Made north of 1350hp...Problem is, no one makes a cast intake for those heads, so that leaves us just one choice... A predator head engine. Problem is the cubes....I don't think there is a moved center line block & head for those available, but if there is, I would go that route but those heads do use a Hemi block, so maybe Best Machine can do another one of those blocks....no idea. Lastly, as suggested, the Pro-stock Hemi 99...But again, the cast intake is the issue...Looks like those use a chevy 4.9 or 5.0 bore space block. Makes sense if you think about it. the chevy guys use non-skirted blocks like PS, and whomever builds one of these is likely to use a GM trans....block would typically be all setup that way. There are a couple for sale right now. Check RJ and For A-bodies only. After all these years, we have trouble getting stock bore space replacement blocks, let alone anything after market to go even further with...Kinda tells you where the Mopar hobby is going...
[Re: AndyF]
#2978105
10/25/21 07:47 AM
10/25/21 07:47 AM
Posts: 1,965 Apollo, PA.
B1MAXX
Apollo, PA.
I think this is a good indicator that the end of the Mopar SB and BB are on the last leg. How often do you see a non hemi Mopar winning at the track or street when the HP requirements are over 1200-1500. Thank God we have a strong foothold on the nostalgia classes, Mopar days and stock eliminator. Yeah I was very surprised to see GM introduce a 1000 hp crate engine. That is crazy but also kind of cool. If those engines are available and the price is fair then you'll start to see a lot of them show up at the track. Mopar Performance could've introduced a 1000 hp big block crate engine years ago when had the blocks but I don't think there was anyone left at MP in those days who had the guts to make a project like that happen. It could've been done but it would've required breaking some of MP's old rules about which kind of parts to use. Yeah, and I can see the local relative well to do midlife crisis GM wing nut buying one putting it in their bracket car and going 10.50's
[Re: B1MAXX]
#2978108
10/25/21 08:17 AM
10/25/21 08:17 AM
GY3
Wichita
I think this is a good indicator that the end of the Mopar SB and BB are on the last leg. How often do you see a non hemi Mopar winning at the track or street when the HP requirements are over 1200-1500. Thank God we have a strong foothold on the nostalgia classes, Mopar days and stock eliminator. Yeah I was very surprised to see GM introduce a 1000 hp crate engine. That is crazy but also kind of cool. If those engines are available and the price is fair then you'll start to see a lot of them show up at the track. Mopar Performance could've introduced a 1000 hp big block crate engine years ago when had the blocks but I don't think there was anyone left at MP in those days who had the guts to make a project like that happen. It could've been done but it would've required breaking some of MP's old rules about which kind of parts to use. Yeah, and I can see the local relative well to do midlife crisis GM wing nut buying one putting it in their bracket car and going 10.50's Or just putting it on display in their mini Garage Mahal.
[Re: GY3]
#2978111
10/25/21 08:39 AM
10/25/21 08:39 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Goodwin Competition made 1200+ HP NATURALLY ASPIRATED w/ an Indy -1 head on a dragweek motor built for nitrous. You believe that? In reality, I think it would take something like a Predator or a good B1 MC or PSO to do it. Or whatever the biggest Indy conventional heads are now...600-13 or something like that?
[Re: an8sec70cuda]
#2978193
10/25/21 12:32 PM
10/25/21 12:32 PM
Al_Alguire
Las Vegas
FWIW the Goodwin stuff, ie 600-13xxx or whatever they call it sure seems capable in the couple that are out there. The cast intake for the 99 can be over come if one doesn't mind spending the $$. Be the same stuff we were forced to do in NA10.5 when we had a large weight break for a cast intake. But it can get really expensive, think two sheet metal intakes for the cost of one cast intake. While I have not ever really given it alot of thought but might be interesting to look at a 99 and see what if any cast intakes out there could be cut up to work. Like was done with the B1TS stuff back in the day. May not be so difficult now alot ore stuff out there. I know of a certain B1TS deal that has two cup intakes cut up and welded to gether in ordr to make the cast intake rule work for them.
[Re: an8sec70cuda]
#2978216
10/25/21 01:22 PM
10/25/21 01:22 PM
n20mstr
Goodwin Competition made 1200+ HP NATURALLY ASPIRATED w/ an Indy -1 head on a dragweek motor built for nitrous. You believe that? In reality, I think it would take something like a Predator or a good B1 MC or PSO to do it. Or whatever the biggest Indy conventional heads are now...600-13 or something like that? I find that 1200 NA from a -1 head hard to believe. Im not saying its not true, but wow thats hard to believe. A -1 head can flow 400cfm, but still hard to believe. Now 1200 with nitrous, yes that i will believe all day long
[Re: n20mstr]
#2978229
10/25/21 01:49 PM
10/25/21 01:49 PM
an8sec70cuda
Goodwin Competition made 1200+ HP NATURALLY ASPIRATED w/ an Indy -1 head on a dragweek motor built for nitrous. You believe that? In reality, I think it would take something like a Predator or a good B1 MC or PSO to do it. Or whatever the biggest Indy conventional heads are now...600-13 or something like that? I find that 1200 NA from a -1 head hard to believe. Im not saying its not true, but wow thats hard to believe. A -1 head can flow 400cfm, but still hard to believe. Now 1200 with nitrous, yes that i will believe all day long Exactly. Some guy all over the Mopar pages on FB has a white Duster he's putting together (writing checks) for drag week, supposedly, and loves posting pics of it. Gets real butthurt when anyone questions it. Goodwin builds some awesome stuff, but I wonder what they know about making power w/ -1 heads that NOBODY else does.
[Re: Al_Alguire]
#2978253
10/25/21 02:32 PM
10/25/21 02:32 PM
AndyF
99 Hemi and be done. Would have to make a "cast" intake but HP goal would be met and exceeded. Yeah, tooling up a cast intake would cost less than trying to make some other combo work. Shouldn't be much more difficult that figuring what really works and then making a pattern. Although I'm not sure how well supported the 99 Hemi is anymore. Might be a struggle to find parts.
[Re: Dragula]
#2978256
10/25/21 02:35 PM
10/25/21 02:35 PM
AndyF
Has to be a Single cast intake single 4, Cast Iron Block Wedge Engine. Has anyone built anything close and tested on a realistic Dyno with numbers? Thanks Mopar has some nice choices at the 1000hp level, not so much at +1200hp level. That's going to be more of a one off, but it can be done. Me, I like the moved Center Line, 4.84 bore space 655 Millenium Hemi that Best Machine did a couple years ago. Made north of 1350hp...Problem is, no one makes a cast intake for those heads, so that leaves us just one choice... A predator head engine. Problem is the cubes....I don't think there is a moved center line block & head for those available, but if there is, I would go that route but those heads do use a Hemi block, so maybe Best Machine can do another one of those blocks....no idea. Lastly, as suggested, the Pro-stock Hemi 99...But again, the cast intake is the issue...Looks like those use a chevy 4.9 or 5.0 bore space block. Makes sense if you think about it. the chevy guys use non-skirted blocks like PS, and whomever builds one of these is likely to use a GM trans....block would typically be all setup that way. There are a couple for sale right now. Check RJ and For A-bodies only. After all these years, we have trouble getting stock bore space replacement blocks, let alone anything after market to go even further with...Kinda tells you where the Mopar hobby is going... I agree. 1000 hp with a Mopar big block should be fairly easy using off the shelf parts, but 1200 hp might be either super difficult or impossible depending on who is doing it and how much money they have to spend.
[Re: AndyF]
#2978261
10/25/21 02:52 PM
10/25/21 02:52 PM
Al_Alguire
Las Vegas
99 Hemi stuff is becoming harder and harder to find. Just went through this with a fellow board member who was trying to locate one. Took alot of phone calls and finally found a customer of a builder that had a spare he was willing to part with.
IMO as I said earlier a 1200 HP BB Mopar can be done. Yes even a single cast 4 can be. A 655" 600-13x deal should get you really close. We have one in bracket mode that makes 1100. We have done a couple Predators that were in the 1150 range with a single 4 so again not full tilt deals but not exactly typical bracket stuff ether. A PSO or TS deal can likely get there as well. Bottom line there are options if you are willing to go out on that ledge and spend the money.
[Re: AndyF]
#2978774
10/27/21 01:28 AM
10/27/21 01:28 AM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
99 Hemi and be done. Would have to make a "cast" intake but HP goal would be met and exceeded. Yeah, tooling up a cast intake would cost less than trying to make some other combo work. Shouldn't be much more difficult that figuring what really works and then making a pattern. Although I'm not sure how well supported the 99 Hemi is anymore. Might be a struggle to find parts. The 99 Hemi isn't a wedge head either as specified in the OP, never mind the intake. I don't think the Predator head would be considered a wedge head either would it?
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: an8sec70cuda]
#2978975
10/27/21 04:35 PM
10/27/21 04:35 PM
Posts: 154 Canada
cuda499
Canada
Goodwin Competition made 1200+ HP NATURALLY ASPIRATED w/ an Indy -1 head on a dragweek motor built for nitrous. You believe that? In reality, I think it would take something like a Predator or a good B1 MC or PSO to do it. Or whatever the biggest Indy conventional heads are now...600-13 or something like that? I find that 1200 NA from a -1 head hard to believe. Im not saying its not true, but wow thats hard to believe. A -1 head can flow 400cfm, but still hard to believe. Now 1200 with nitrous, yes that i will believe all day long Exactly. Some guy all over the Mopar pages on FB has a white Duster he's putting together (writing checks) for drag week, supposedly, and loves posting pics of it. Gets real butthurt when anyone questions it. Goodwin builds some awesome stuff, but I wonder what they know about making power w/ -1 heads that NOBODY else does. "Happy Dyno"......... because the scales and MPH dont lie! FWIW, have done a predator build with a single carb. mid 13:1 compression and cam was nitrous orientated with factory seized cam core!!!!!! made 1138 with lots of room for improvment. 1/8 went 122mph @ over 3800lbs and over 5000ft of air.
[Re: cuda499]
#2979196
10/28/21 10:24 AM
10/28/21 10:24 AM
Posts: 4,563 Motor City
6PKRTSE
Motor City
There are alot of single cell happy dyno's out there for sure. As mentioned the track will tell for sure. All 42 of our dyno rooms are SAE calibrated and certified for all of our OEM and prototype development we do, so I know when we dyno engines are numbers are true.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Mpetros]
#2979886
10/30/21 12:39 PM
10/30/21 12:39 PM
Al_Alguire
Las Vegas
No weight rule or minimum?
[Re: dthemi]
#2979990
10/30/21 05:59 PM
10/30/21 05:59 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't know if I fully understand this, but if factory BS is at play, no better option than a big Ford. A thor headed ford, would dominate any manufacturer. Chevy and mope would be way behind if there is something other than just anything goes.
For a mope, I still haven't seen anything better than a good set of predators. Better than any hemi NA that I've seen so far.
I've been playing with a pair of mechanical injected blown hemis in two cars, and have let my predator motors languish. I'm building a 4.9 bs noonan and having the second frame rail added to my stratus to deal with it. My plan is to take the 660 nitrous predator in it now, and make it NA single 4 over the winter using a get'm carb. I'll post progress as it goes.
What is this class you guys are talking about called?
He has a pulling truck.
[Re: Mpetros]
#2987993
11/22/21 07:58 PM
11/22/21 07:58 PM
Al_Alguire
Las Vegas
Hemi pattern heads are a bit better some believe. We have had Slawko do both and didn't see any difference.
[Re: Mpetros]
#2988024
11/22/21 09:22 PM
11/22/21 09:22 PM
polyspheric
New York
Hate to point this out, but the BBC and BBF (FF, 385) are not wedge engines.
Boffin Emeritus
