340 T/A Rocker Shaft Torque ? #2976901
10/21/21 05:21 PM
10/21/21 05:21 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Hey guys im a little baffled on this,
service manual says 318-340 torque to 210 in. pounds.
the tightening reference says rocker shaft bracket bolt 25 ft. pounds .
so, any idea what it should be, Do the T/A shaft take a different size bolt from a regular 340 ? Thanks, Kevin
Re: 340 T/A Rocker Shaft Torque ? [Re: B5TA] #2976934
10/21/21 07:12 PM
10/21/21 07:12 PM
I think the Mopar factory service manuals call for 23 Ft. Lbs.. I convert that to inch lbs. (12x23 Ft. Lbs. =276 inch lbs.) and use a inch lb. torque wrench to torque them down several times to make sure the fasterners are stretch as tight as they will stay at wrench scope twocents
Re: 340 T/A Rocker Shaft Torque ? [Re: Cab_Burge] #2977089
10/22/21 01:43 AM
10/22/21 01:43 AM
CA
crackedback Offline
crackedback  Offline
CA
200 inch pounds, about 17 ft lbs
25ft will snap bolts
look up torque specs for 5/16 bolts. iirc, a grade 8 is 20 max
they are not 3/8 like one of the popular sources claim
Re: 340 T/A Rocker Shaft Torque ? [Re: B5TA] #2977095
10/22/21 02:53 AM
10/22/21 02:53 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi '
200 in lb for sure !
multiplying by 12 does NOT give correct value !
Re: 340 T/A Rocker Shaft Torque ? [Re: crackedback] #2977777
10/24/21 07:08 AM
10/24/21 07:08 AM
New Jersey
Claw57 Offline
Claw57  Offline
New Jersey
Agree. (DAHIK).
Because I like it that way.
