Re: Indy 3X , 550 cubes, gains from p porting the intake?
[Re: HardcoreB]
#2978534
10/26/21 10:47 AM
10/26/21 10:47 AM
Posts: 10,036 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Sorry I was out on vacation for a long weekend. That manifold didn't look too bad, but as has been mentioned I'm going to speculate that when it comes back from 'Florida' it won't have the clover up top and it won't have required any welding. I'm sure it'll be an improvement. I look forward to new results! Me too😁
[Re: gregsdart]
#2978617
10/26/21 03:05 PM
10/26/21 03:05 PM
Posts: 10,050 MN
JERICOGTX
MN
Here is a picture of a 440-3 intake, and 440-3X side by side.
69 GTX
68 Road Runner
[Re: AndyF]
#2978892
10/27/21 12:46 PM
10/27/21 12:46 PM
Posts: 19,400 Las Vegas
Al_Alguire
Las Vegas
Well I will say that one is on a BIG engine. To be honest I was very impressed with how it came out, both engine and intake. Makes very good power numbers but that's just a dyno number-but for a .500/.488 lobe and under 14-1 it works well. I has been low 7.20's in a 1900lb dragster here in Vegas in the summer.
[Re: gregsdart]
#2978989
10/27/21 05:21 PM
10/27/21 05:21 PM
Al_Alguire
Las Vegas
Greg, No I did not had a very smart former? board member here do it. I can tell you its runs better than it did with 2x4 set up and on the dyno that was about 40HP but also two different dynos.
[Re: Al_Alguire]
#2983851
11/10/21 03:48 PM
11/10/21 03:48 PM
gregsdart
Talked to Wilson Manifolds yesterday and i am having a " mid level full port" done. That includes work on full length of the runners but no major cutting I assume. Since there are a lot of changes to the combo, the comparison to the " before" dyno numbers will be hard to figure. The changes are- Changed from Milodon gear drive to belt drive. .240 longer rods .036/036/3mm rings with lower tension, from .043/.043/3/16 low tension? Gibtech pistons, L2L coated on skirts same as original pistons. New wrist pins, DLC COATED .205 wall thick( from .180) BMP block, aluminum versus iron megablock Same center weighted Crower crank, which I hope will reduce any issues of distortion and ring seal that may come from a non center weighted crank. Everything else will remain the same dyno sheet from June 2020
[Re: HardcoreB]
#2984394
11/12/21 07:14 AM
11/12/21 07:14 AM
gregsdart
Did you have Jones make you this cam? Did he recommend spring loads? What's the #'s 050 200 LSA? Lobe lift? Jones spec'd it out. Inverted flank roller, .510 intake lobe .480 ex lobe. 1.7 Jesel Rockers. Duration @ .050 int 284 ex 296 . 113LSA in at 111. .200 numbers are ? 205 int?. Lash is .019 int and .020 ex.
[Re: HardcoreB]
#2984447
11/12/21 11:20 AM
11/12/21 11:20 AM
gregsdart
D Nice! Did he spec you Seat/Open valve loads? I told him what I was using and as I recall that was deamed ok. Due to economy I stayed with comp 947 triples on exhaust. Set at about 330 lbs on the seat. Intakes I had to go to PAC 1228 due to net lift of .848 after lash. Those ended up at 2.070 as I recall with about 310 lbs on the seat. The 1228 springs have a 2.100 spec installed hieght with 280 pds. At 2.070 they ended up at what I thought was enough since they have less mass than the 947s. The 2.070 is about max for -1 heads and I needed +.100 retainers and +.050 retainers combined with spring cups that are .030 thick.
[Re: AndyF]
#2987349
11/21/21 12:07 AM
11/21/21 12:07 AM
gregsdart
Looks great. Should pick up some power for you. I've tested a lot of Wilson intakes and they are usually 20 to 30 hp better than as cast. Sounds great to me Andy. I was concerned it may not gain that much due to the methanol port injection, will be interesting when I get it on the dyno.
[Re: gregsdart]
#2987460
11/21/21 12:24 PM
11/21/21 12:24 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Port injection?
So I guess it still has to have the fuel rails, etc installed.
