Do crate engines have VVT? #2975384
10/17/21 05:11 PM
10/17/21 05:11 PM
BDW Offline OP
BDW  Offline OP
Looking at Holley oil pans, they have VVT and non-VVT versions?
I'm really considering a 5.7 crate engine, but may consider a wreck pulled motor.
Do the new crate motors need the VVT oil pan?
On a used motor, what year or option determines if it has VVT?
Sorry for the basic questions. I'm in learning and parts gather mode right now, and looking at oil pans.
Any better option than the cast aluminum Holley offering?
Thx
Re: Do crate engines have VVT? [Re: BDW] #2975403
10/17/21 07:03 PM
10/17/21 07:03 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
All the new factory crate engines are VVT. 2009 up 5.7 and all 6.2-6.4 are VVT.
I can't help on oil pans.
87 dakota 6.1 hemi
Re: Do crate engines have VVT? [Re: Glen440] #2976449
10/20/21 12:00 PM
10/20/21 12:00 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Have you looked at non factory crate engines? When searching for a builder for a 440 I learned quickly that so many shops have switched to building Gen3 Hemis and gotten out of the business of the old stuff for the most part. Not only big ones like Hughes and Mancini but the smaller mom and pop shops. They can build you a nice crate Gen3 however you want. Just a thought.
Facts are stubborn things.
Re: Do crate engines have VVT? [Re: larrymopar360] #2976637
10/20/21 09:34 PM
10/20/21 09:34 PM
BDW Offline OP
BDW  Offline OP
Hadn't thought of that option, got any leads for 3G builders?
Thx
Re: Do crate engines have VVT? [Re: BDW] #2976673
10/20/21 10:59 PM
10/20/21 10:59 PM
IL
furious70 Offline
furious70  Offline
IL
Holley has some good videos up about their stuff and gen III. Motortrend/hot rod does too.
There are other options
https://www.bouchillonperformance.com/
mancini
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Do crate engines have VVT? [Re: BDW] #2976946
10/21/21 07:35 PM
10/21/21 07:35 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Thx
I'll post my 440 swap thread here. There were several recommended builders by members here and when I called them they pretty much all but said "not interested we only do Gen3 hemis now"
Re: Do crate engines have VVT? [Re: larrymopar360] #2977069
10/22/21 12:22 AM
10/22/21 12:22 AM
What does VVT stand for help
I'm starting to think of trying to a Gen 3 motor (instead of another stroker B motor) for a car I own and want to experiment with one of them work
I know there is a lot to learn hence me asking about this help
Thanks in advance: Cab
Re: Do crate engines have VVT? [Re: Cab_Burge] #2977077
10/22/21 12:37 AM
10/22/21 12:37 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Cab,
Variable Valve Timing.Oil pressure controls the advancing/retarding of cam timing.
Re: Do crate engines have VVT? [Re: BDW] #2977108
10/22/21 06:14 AM
10/22/21 06:14 AM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
Not sure if you found your answer yet, but the retrofit pans are the same, it's the oil pick-up tube that changes with the later vvt engines. Since the Holley pans come as a kit, you'll see them advertised by vvt and non-vvt, which is just a way to describe early versus late engines.
Re: Do crate engines have VVT? [Re: todd440] #2977592
10/23/21 02:21 PM
10/23/21 02:21 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
09 and up with Eagle Heads are VVT
Re: Do crate engines have VVT? [Re: RTSrunner] #2977605
10/23/21 02:56 PM
10/23/21 02:56 PM
I remember that about 45 minutes after asking blush
Man do things change when you old, over 75 shruggy whistling
The alternative is not something I'm wanting to go through soon tsk grin shruggy
All life ends at death shruggy
Re: Do crate engines have VVT? [Re: Cab_Burge] #2977701
10/23/21 07:58 PM
10/23/21 07:58 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
LOL Cab, we want you around too.
Re: Do crate engines have VVT? [Re: larrymopar360] #2977731
10/23/21 09:43 PM
10/23/21 09:43 PM
USA
hudsonhornet7x Offline
USA
Hey Cab, you have given me lots of good advice before and if I can return the favor just PM me. I have learned some about the gen III although I am no expert.
Re: Do crate engines have VVT? [Re: hudsonhornet7x] #2978518
10/26/21 10:15 AM
10/26/21 10:15 AM
BDW Offline OP
BDW  Offline OP
From what I’m seeing, used motors are just as expensive as the crates.
And there’s no Mopar crate motors in stock.......
Re: Do crate engines have VVT? [Re: BDW] #2978730
10/26/21 08:39 PM
10/26/21 08:39 PM
I was going to start cruising the junkyards within a 150 mile radius east of Bend looking for motor in a pickup for my first Gen 3 Hemi project.
What is, in all of your opinions, is the best one to start with, remember I'm old school and like big C.I. to start with and I don't mind having a iron block up
What years did the 6.2 and 6.4 motors come in?
Did Dodge make any of the later pickups with a SRT type 6.2 or 6.4 motor in them? help
I'm not looking for a blown motor but if they are out there I won't rule the out, depending on the price.
Last question I can think of now is which brand EFI adapter ECU kit will work with those motors in a early 1967 B body? help
I'm not a ECU tuner but I can learn and adapt shruggy whistling devil
No real reason not too up
Thanks in advance for all of your help on this deal bow
Re: Do crate engines have VVT? [Re: Cab_Burge] #2978752
10/26/21 09:39 PM
10/26/21 09:39 PM
USA
USA
Cab,
Here are a few of your answers:
6.2 hemi= 2015 and up
6.4 hemi=2012 and up
Dodge trucks have had the 6.4 since 2014 I believe.
Holley has efi that will work with these engines. They along with EFI source in Pennsylvania are two of the biggies.
Mopar has what they call plug and play kits- if you are leaving the engines stock these are by far the easiest ways to go. A few simple connections and you are running/driving.
As far as what engine would be best for you, I would like to ask what your intentions are as far as driving/racing, and will you ever want a power adder?
