Driveshaft and conversion u joint qusetion #297637
04/23/09 05:43 PM
04/23/09 05:43 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
After my gear swap I found out I have a the wrong driveshaft in my car.
I have the driveshaft for an 8 3/4 rear wich is 52" I need a 51" per the manual, actually 50.96" anyway instead of shortening a good 8 3/4 rear driveshaft That I can save for another car I thought I can use what I had handy.
I have an aluminum driveshaft from a crown vic police car. it has 1330 u joints. I was quoted $75.00 to shorten and balance it. Then I would use a 1330/7290 conversion joint.
I think this should work fine
Is this a bad idea ? if so please explain.
I kinda dont want to buy a custom shaft or change the trans and rear end yoke if I dont have to.
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297638
04/23/09 05:51 PM
04/23/09 05:51 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I don't see why that would be a bad thing.
use the Brute Force or extreme duty u joints with no grease fittings. link to the u joints
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297639
04/23/09 06:04 PM
04/23/09 06:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The "cross" for the Spicer u-joints that I have are the same for the 1330 and 7290, only the caps are different. If your's is the same, then you'll only need to change the caps.
Re: Driveshaft and conversion u joint qusetion [Re: BSB67] #297640
04/23/09 06:38 PM
04/23/09 06:38 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
Is that the part number for the 1330/7290 joint? if not anybody have the part number?
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297641
04/23/09 07:33 PM
04/23/09 07:33 PM
N.H.
mopar-addiction Offline
N.H.
Spicer # 5-796X is the 1330/7290 U-joint
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297642
04/23/09 07:43 PM
04/23/09 07:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats the diameter on the alum shaft and how much
power are you making
Re: Driveshaft and conversion u joint qusetion [Re: MR_P_BODY] #297643
04/23/09 10:41 PM
04/23/09 10:41 PM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
just under 3 1/2" diameter and I am making about 550hp. Is that going to be o.k. in a heavy car or should I stick to steel?
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297644
04/23/09 11:12 PM
04/23/09 11:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That should be fine. I'm assuming that its mainly a
street car
Re: Driveshaft and conversion u joint qusetion [Re: MR_P_BODY] #297645
04/24/09 12:14 AM
04/24/09 12:14 AM
Overland Park, KS.
Joshs68 Offline OP
Joshs68  Offline OP
Overland Park, KS.
for the most part yes it is,
I have plans to run it this summer now that the kiddo is a little older.
we have 1/8 mile pretty close and I am going to start there. If I can get to the track 4-6 times a year I would be happy.
Re: Driveshaft and conversion u joint qusetion [Re: Joshs68] #297646
04/24/09 12:05 PM
04/24/09 12:05 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have a crown vic drive shaft in my Valiant. I think your going to be OK
The Valiant has been 1.31 in sixty feet with a 500ci wedge
