Best Exhaust Bolt to Head Sealant Opinions Please.
#2975692
10/18/21 02:45 PM
10/18/21 02:45 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Getting ready to put my stock exhaust manifolds back on the 71 340 Cuda. I've had issues with leaky threads in the head coolant port areas in the past with other projects. What is the best sealant to use these days to prevent this?
Thanks !!
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Best Exhaust Bolt to Head Sealant Opinions Please.
[Re: Cab_Burge]
#2975723
10/18/21 03:45 PM
10/18/21 03:45 PM
TimS
Walton, Indiana
I like and use Permatex brand Adhesive Silicone for thread sealing, works good too I use to buy and use the G.M brand thread sealer but not anymore after their latest formula change The copper hi temp stuff?
[Re: TimS]
#2975734
10/18/21 04:00 PM
10/18/21 04:00 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
I like and use Permatex brand Adhesive Silicone for thread sealing, works good too I use to buy and use the G.M brand thread sealer but not anymore after their latest formula change The copper hi temp stuff? No, it is not a adhesive type silicone
[Re: rickraw]
#2975852
10/18/21 08:07 PM
10/18/21 08:07 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Teflon tape and Teflon pipe dope, it will never leak. The Permatex or ARP stuff in a container with a brush. Make sure both parts are as clean as you can possibly get them and brush some Teflon sealer on the threads and you are good to go. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2975972
10/19/21 06:30 AM
10/19/21 06:30 AM
TimS
Walton, Indiana
Thanks very much for the recommendations.
[Re: fourgearsavoy]
#2975990
10/19/21 08:42 AM
10/19/21 08:42 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
[q uote=rickraw]Teflon tape and Teflon pipe dope, it will never leak. The Permatex or ARP stuff in a container with a brush. Make sure both parts are as clean as you can possibly get them and brush some Teflon sealer on the threads and you are good to go. Gus [/quote]
