Page 2 of 5 1 2 3 4 5
Re: 426 Hemi rebuild... [Re: moparx] #2726136
12/22/19 02:51 PM
12/22/19 02:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
WOW VERY well done shop ,No more pictures of my car in the garage LOL,
Re: 426 Hemi rebuild... [Re: Cab_Burge] #2726189
12/22/19 05:25 PM
12/22/19 05:25 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Originally Posted by Cab_Burge
Polishing the intake port walls leads to fuel separating from the air at idle and low air speeds, you might want to make them not so shiny now to help avoid that work
I would check the lift at on all the valves at the retainers with checking springs to see how close your rocker arms are as far as their actual ratio are scope I've seen .130 lift differences when checking rocker arms from 4 different motors when I was blueprinting a NHRA stocker motor puke shruggy
Way back in the early 70's when Jack Roush was into Drag Racing that 4 door Maverick he put on a seminar and stated the same thing about over polishing the intake ports. Stated to match port the intake to heads , remove any big goobs and leave the rest of the head intake ruff. He was racing a Ford , but to me at that time made sense.
Re: 426 Hemi rebuild... [Re: Cab_Burge] #2726200
12/22/19 06:29 PM
12/22/19 06:29 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
It amazes me how nice you can make a shop with enough money and desire up bow
I'm not showing mine whistling
iagree me either ...only the outside
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 426 Hemi rebuild... [Re: W.I.N. Racing] #2726246
12/22/19 08:32 PM
12/22/19 08:32 PM
rowin4 Offline
rowin4  Offline
My shop might have looked like that back in 1926 when it was built as a car dealership. It's only 10,000 square feet though, small by todays standards. Extra room? nope !!!!!!!.
Re: 426 Hemi rebuild... [Re: rowin4] #2726251
12/22/19 08:55 PM
12/22/19 08:55 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Lmao, well thanks again guys, much appreciated.
10k sq/ft is mega! Having an old car dealer as a shop sounds awesome.
Re: 426 Hemi rebuild... [Re: INTMD8] #2727060
12/26/19 01:40 PM
12/26/19 01:40 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Ha! Wow smile
Well I'm glad I asked...that looks fantastic. Thanks for the pics.
Rich H.
Esse Quam Videri
Re: 426 Hemi rebuild... [Re: ZIPPY] #2727189
12/26/19 07:59 PM
12/26/19 07:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Nice Clean Looking Shop!. I Know This Is a Mopar Site but I love that Caddy! I have one of those Bailey electric magnetic brakes as well. They're pretty sweet
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 426 Hemi rebuild... [Re: Hemi_Joel] #2729764
01/03/20 07:13 PM
01/03/20 07:13 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks again guys smile
Yes I don't use the Baileigh tools that often but definitely nice to have when you need it.
I don't have much of an update with the holidays but parts are coming in......
Re: 426 Hemi rebuild... [Re: INTMD8] #2729767
01/03/20 07:31 PM
01/03/20 07:31 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Are you using Edelbrock EFI or just the manifold? I've not seen too many positive reviews of their EFI when coloring outside the box they usually play in and that roller seems a good bit down the road and around the corner from that box.
Kevin
Re: 426 Hemi rebuild... [Re: Twostick] #2729815
01/03/20 09:09 PM
01/03/20 09:09 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
I'm using (well intend to use) their EFI. Part # 35670
I followed the pro flo 4 forum for a while and it seemed mostly positive feedback. Some guys running cams with 7-8in vacuum at idle with no reported issues.
System is rated at 825hp so you would think it could take some cam......but if not, I'll change the ecu it to something with full access to all parameters. (Dominator?)
Would still be able to use the entire setup minus the ECU and wiring harness and it's not a bad deal for those parts alone at the price I bought it for.
Re: 426 Hemi rebuild... [Re: INTMD8] #2742325
02/12/20 03:30 PM
02/12/20 03:30 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Progress is very slow!
Received the pistons finally. smile
Re: 426 Hemi rebuild... [Re: INTMD8] #2742330
02/12/20 03:35 PM
02/12/20 03:35 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Old piston-
Re: 426 Hemi rebuild... [Re: INTMD8] #2742395
02/12/20 06:54 PM
02/12/20 06:54 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Let me know when you're ready for a Holley.
fastmanefi.com
Re: 426 Hemi rebuild... [Re: INTMD8] #2742549
02/13/20 11:52 AM
02/13/20 11:52 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Tell us about your heating system in the pole barn
Re: 426 Hemi rebuild... [Re: RATTRAP] #2742566
02/13/20 12:53 PM
02/13/20 12:53 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
It's a 3 ton unit. Heat and A/C.
Re: 426 Hemi rebuild... [Re: INTMD8] #2776824
05/21/20 06:29 PM
05/21/20 06:29 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Progress still verrrry slow. I'm told the short block should be ready for assembly next week. Also finally have flow numbers so I will get to work on the camshaft. From SF600 flow bench.
Re: 426 Hemi rebuild... [Re: INTMD8] #2776975
05/22/20 10:48 AM
05/22/20 10:48 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Very nice, but that pool table is taking up space for another Mopar.
Re: 426 Hemi rebuild... [Re: jbc426] #2777011
05/22/20 01:02 PM
05/22/20 01:02 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I'd sell the caddy and keep the pool table but the black cloth has gotta go.
Re: 426 Hemi rebuild... [Re: @#$%&*!] #2777046
05/22/20 02:18 PM
05/22/20 02:18 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Haha, can't sell the Caddy. Might eventually move the pool table to the basement but have 2 other garages so not out of space (yet).
Re: 426 Hemi rebuild... [Re: INTMD8] #2785375
06/14/20 01:09 PM
06/14/20 01:09 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Short is done. Getting the rest of the parts together to finish assembly.
