Small block oil pan ?
#2974050
10/13/21 06:32 PM
10/13/21 06:32 PM
Posts: 4,673 On the parachute mount
n20mstr
What’s a good pan ? Not hanging super low and something good because I think the car will be pretty quick . And do all pans clear 4.125 stroke or does it take a special pan ? Do we need rear sump ?
....BAD A$$ STREET CAR.....
Re: Small block oil pan ?
[Re: n20mstr]
#2974055
10/13/21 06:47 PM
10/13/21 06:47 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’ll tell you what NOT to get. The Milodon oil pan that I’ve bought seven of over the years. Those azz-hats even though they deny it changed the design and turned it into a piece of crap. I talked to hem six times and emailed pictures and he still said they didn’t change it. The pickup wasn’t close to using and the rods hit on a Chevy sized 4” stroke engine. Even though they advertised it’s good with a 4.125 stroke crank. He ended up saying because I spent two days modifying it he would send me a free pan. Nothing yet and that was 8 months ago. I won’t put pictures on this site as it’s a pain in the butt. I quit putting any tech here.
[Re: pittsburghracer]
#2974056
10/13/21 06:48 PM
10/13/21 06:48 PM
Posts: 20,163 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Ohhhh pictures are on Abodiesonly if you want to see it.
#2974078
10/13/21 07:28 PM
10/13/21 07:28 PM
n20mstr
Will stock pans clear the longer stroke ?
#2974165
10/13/21 10:49 PM
10/13/21 10:49 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I have had great luck with the milodon pan. They say 8qt but I usually run 6 on drag week and 5 in normal street driving and race scenarios. My current one was bought in 2015 so maybe they changed? It looked exactly like the one I had from 2010. It hangs just a few inches below the stock k-member and has not caused me any trouble with clearance and my car sits pretty low.
68 Barracuda Formula S 340
[Re: DusterKid]
#2974211
10/14/21 07:59 AM
10/14/21 07:59 AM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
I run Morosos on my small blocks, no clearance problems on my 408 stroker.I just put my 363 back in with a new Moroso pan, I have the old one if you want to try it , in good shape I just like the finish they put on the new ones so I got a new one. I forget which motor you run the pan is for a 360. PM me if you are interested.
