Gas Pedal? #2973535
10/12/21 03:04 PM
10/12/21 03:04 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Do you run a cable or solid rod on your drag car?
Re: Gas Pedal? [Re: bobs69] #2973540
10/12/21 03:12 PM
10/12/21 03:12 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Stock 64 throttle cable. Then needed something longer. Now a $20 universal braided throttle cable. In 9 years (750 passes) of running the only throttle issues; were broken carb stud, broken weld on the stock pedal pivot. Never any cable issues.
Doug
Re: Gas Pedal? [Re: bobs69] #2973552
10/12/21 03:35 PM
10/12/21 03:35 PM
Both, depending on which race car up work grin whistling
Re: Gas Pedal? [Re: Cab_Burge] #2973558
10/12/21 03:57 PM
10/12/21 03:57 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Solid rod.
Re: Gas Pedal? [Re: markz528] #2973659
10/12/21 07:39 PM
10/12/21 07:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Solid rod, like on a chassis car, or Morse cable, like on a dragster, with a toe hook on the pedal is a little extra safety deal if the throttle hangs or springs break.
Using a stock cable, make sure the return springs are in good shape.
Re: Gas Pedal? [Re: bobs69] #2973680
10/12/21 08:25 PM
10/12/21 08:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Still running my original slant 6 cable shruggy it only has about 100k on it
If it ever goes I'll probably replace it with another one twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Gas Pedal? [Re: fourgearsavoy] #2973698
10/12/21 09:17 PM
10/12/21 09:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Gus beer
Same here !
Re: Gas Pedal? [Re: CMcAllister] #2973707
10/12/21 09:27 PM
10/12/21 09:27 PM
[quote=CMcAllister Morse cable, like on a dragster, with a toe hook on the pedal is a little extra safety deal if the throttle hangs or springs break. [/quote]
i haven't seen or heard of a toe hook on the gas pedal in a long time, my S/P car doesn't have one with a the big Morse cable for the gas pedal shruggy
maybe I shouldn't say that, huh whistling work grin
Re: Gas Pedal? [Re: VernMotor] #2973712
10/12/21 09:32 PM
10/12/21 09:32 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Gus beer
Same here !
x3 here also up
Re: Gas Pedal? [Re: Cab_Burge] #2973733
10/12/21 10:06 PM
10/12/21 10:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
maybe I shouldn't say that, huh whistling work grin [/quote]
I got one. Wompin' it or lifting, I know the throttle is going to follow the foot.
Re: Gas Pedal? [Re: CMcAllister] #2973745
10/12/21 10:52 PM
10/12/21 10:52 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I changed out the cable for a direct rod on my 64 Plymouth. My reaction times became more precise and consistent.
Re: Gas Pedal? [Re: cudaman1969] #2973751
10/12/21 11:22 PM
10/12/21 11:22 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Stock cable.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Gas Pedal? [Re: bobs69] #2973786
10/13/21 07:10 AM
10/13/21 07:10 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Stock cable on all of our cars.
Re: Gas Pedal? [Re: DusterKid] #2974009
10/13/21 04:03 PM
10/13/21 04:03 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Stock cable.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
