Re: Gas Pedal?
[Re: markz528]
#2973659
10/12/21 07:39 PM
10/12/21 07:39 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Solid rod, like on a chassis car, or Morse cable, like on a dragster, with a toe hook on the pedal is a little extra safety deal if the throttle hangs or springs break.
Using a stock cable, make sure the return springs are in good shape.
Re: Gas Pedal?
[Re: bobs69]
#2973680
10/12/21 08:25 PM
10/12/21 08:25 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Still running my original slant 6 cable it only has about 100k on it If it ever goes I'll probably replace it with another one Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Gas Pedal?
[Re: fourgearsavoy]
#2973698
10/12/21 09:17 PM
10/12/21 09:17 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Still running my original slant 6 cable it only has about 100k on it If it ever goes I'll probably replace it with another one Gus Same here !
Re: Gas Pedal?
[Re: VernMotor]
#2973712
10/12/21 09:32 PM
10/12/21 09:32 PM
Posts: 4,072 Mo.
racerx
Mo.
Still running my original slant 6 cable it only has about 100k on it If it ever goes I'll probably replace it with another one Gus Same here ! x3 here also
Re: Gas Pedal?
[Re: Cab_Burge]
#2973733
10/12/21 10:06 PM
10/12/21 10:06 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
[quote=CMcAllister Morse cable, like on a dragster, with a toe hook on the pedal is a little extra safety deal if the throttle hangs or springs break. i haven't seen or heard of a toe hook on the gas pedal in a long time, my S/P car doesn't have one with a the big Morse cable for the gas pedal maybe I shouldn't say that, huh [/quote] I got one. Wompin' it or lifting, I know the throttle is going to follow the foot.
