1973 Charger heater core #2973366
10/12/21 11:43 AM
10/12/21 11:43 AM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Hi folks,
My 73 Charger Rallye sprang a heater core leak. It is not a factory AC car.
I would like to remove the heater core before I buy a replacement. Service manual is not very detailed.
Wondering if it is possible to get to the heater core without removing the whole heater housing (plenum).
I'm guessing it's not possible, but I thought I'd ask anyway.
Thanx in advance.
Re: 1973 Charger heater core [Re: Gabmando] #2973383
10/12/21 12:22 PM
10/12/21 12:22 PM
moparx Offline
moparx  Offline
unfortunately, the box needs to come out, then disassembled to r&r the core.
beer
Re: 1973 Charger heater core [Re: moparx] #2973616
10/12/21 05:25 PM
10/12/21 05:25 PM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
Even if it was posible to remove the half box ( which I think it is ) it makes no sense and would be harder try to keep just the other half of the box attached to firewall. Better to remove the full box and dissasemble the box on bench.
Is easier than it looks... just need to dissasemble the glove box lid and liner to get more room, and remove nuts from engine bay side of firewall, aside the hoses of course. Dunno if the heater box can be pulled out with blower still attached, but on 71/74 B bodies the A/C box is posible.
Re: 1973 Charger heater core [Re: NachoRT74] #2976312
10/19/21 10:27 PM
10/19/21 10:27 PM
TC, Minnesota
Gabmando Offline OP
Gabmando  Offline OP
TC, Minnesota
Thank you for the responses. I have a Strato Vent plenum from a 1972 Charger I used to own. The heater core might just be the same if I'm lucky.
Otherwise, it might be the time to take the leap and install aftermarket AC once and for all.
