73 scamp tranny lines #297275
04/23/09 10:45 AM
04/23/09 10:45 AM
Anonymous OP
Anonymous OP
I installed a 383bb / 727 trans in my 73 scamp. Does anyone have pics of the trans cooler lines hooked up with a trans cooler. I was told to go to the external cooler first and then the radiator. I am not sure of the best way to hook this up so it looks good.
Re: 73 scamp tranny lines #297276
04/23/09 01:42 PM
04/23/09 01:42 PM
Sterling Heights,Michigan
DusterTim Offline
DusterTim  Offline
I think you want to go to radiator first then to external cooler then back to trans, if you do it your way the radiator will heat oil up before going to trans. I did mine the way I said first and trans is always below 150 deg.
Re: 73 scamp tranny lines [Re: DusterTim] #297277
04/23/09 02:05 PM
04/23/09 02:05 PM
United States
STLDuster Offline
STLDuster  Offline
United States
"No great genius has ever existed without some touch of madness." - Aristotle
Re: 73 scamp tranny lines [Re: STLDuster] #297278
04/23/09 06:16 PM
04/23/09 06:16 PM
Anonymous OP
Anonymous OP
Thanks for the diagram.
