440 Rear Main Seal #2971790
10/07/21 05:52 PM
10/07/21 05:52 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I was going through my spare parts, and found two Mopar Performance rear main seal kits for a 440 big block.
P4271961, They have the regular black rubber lip seals, and red rubber side seals. Just like this kit on Mancini
Mancini rear main seal kit (LINK)
Do these hollow red rubber side seals work well?
Re: 440 Rear Main Seal [Re: 440Jim] #2971796
10/07/21 06:02 PM
10/07/21 06:02 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
They work fine. I glued them to the retainer with 3m adhesive, smeared a film of silicone sealer on the seals. Retainer slid right in.
Re: 440 Rear Main Seal [Re: 440Jim] #2972017
10/08/21 11:54 AM
10/08/21 11:54 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
don't you have to push a pin in the side seals once assembled to spread them?
Re: 440 Rear Main Seal [Re: jwb123] #2972023
10/08/21 12:07 PM
10/08/21 12:07 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
YES... install the pin ... its needed to expand the rubber side seals/
Re: 440 Rear Main Seal [Re: jwb123] #2972024
10/08/21 12:10 PM
10/08/21 12:10 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I only use the Fel-Pro Vito rear main seals, part number 2947 and cost $25-$30.
Taken from 440Source "They have a much greater resistance to high temperatures than standard rubber. It also doesn't have a tendency to dry out and shrink over time."
I also do not use the side seals, I use black RTV, either Permatex Ultra Black or Right Stuff. I clean the surfaces, fill in the sides and then installed the seal and then fill in the back cavity with RTV.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 440 Rear Main Seal [Re: WadeMetzinger] #2972263
10/08/21 11:59 PM
10/08/21 11:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I dont use any side seals. Ultra grey by itself. Zero leakage.
Doug
Re: 440 Rear Main Seal [Re: dvw] #2972270
10/09/21 12:23 AM
10/09/21 12:23 AM
Boise
Moparteacher Offline
Boise
I fill in the sides with RTV and then slide in a piece of copper rod to expand the RTV. Trim flush.
Permatex aviation gasket sealant on the back sides of the seals and between the retainer and block.
Re: 440 Rear Main Seal [Re: dvw] #2972271
10/09/21 12:25 AM
10/09/21 12:25 AM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
I have done it both ways with big block mopars, but my last few I've been using Permatex Ultra Black on the sides with success. It does depend on the RMS retainer you're using. Some aftermarket units use two thin rubber seals. Those channels would be too hard to fill with RTV from the top. My most recent build was a Ford FE Big Block which has the same type of side seal / pin system (as the topic starter pictured) and I again filled the void with the Ultra Black. It works very well.
The trick is using the supplied screw on applicator that comes with the Permatex. You get the nose of the applicator in side the void and squeeze hard filling the void completely. I use one of the intended rubber side seals to push the Ultra Black down and pack it in the void. Then I top it off until it's oozing out the top and wipe flush.
Ultra Black takes a while to dry when thick, so I recommend letting it set up for a few days before adding oil / starting the engine.
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: 440 Rear Main Seal [Re: Mopar Mitch] #2972310
10/09/21 08:55 AM
10/09/21 08:55 AM
A727Tflite Offline
A727Tflite  Offline
Anyone have a picture of the pin mentioned here?
Re: 440 Rear Main Seal [Re: A727Tflite] #2972489
10/09/21 07:52 PM
10/09/21 07:52 PM
Alberta
440_Offroader Offline
Alberta
X2, never seen the mentioned pin. Sounds like a good idea though....
Re: 440 Rear Main Seal [Re: 440_Offroader] #2972531
10/09/21 09:14 PM
10/09/21 09:14 PM
Indiana
Gabby63 Online content
Gabby63  Online Content
Indiana
I have never had issues with the Indy Billet retainer leaking . Yes always used RTV sealer . Gary
Re: 440 Rear Main Seal [Re: Moparteacher] #2972729
10/10/21 03:38 PM
10/10/21 03:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A water-dampened pipe cleaner to expand the RTV works better. RTV sets up by exposure to moisture.
Re: 440 Rear Main Seal [Re: John_Kunkel] #2972735
10/10/21 03:53 PM
10/10/21 03:53 PM
Mopar Mitch Offline
Mopar Mitch  Offline
This is exactly correct!!! RTV must have humidity to cure.
Re: 440 Rear Main Seal [Re: Mopar Mitch] #2972747
10/10/21 04:12 PM
10/10/21 04:12 PM
shock I did not know that, I thought it needed exposed to air shruggy
I've never sprayed water on the back, crank flange side, of the main seals after sealing them with adhesive silicone on any of the motors I've built work shruggy
Re: 440 Rear Main Seal [Re: Cab_Burge] #2973031
10/11/21 01:14 PM
10/11/21 01:14 PM
moparx Offline
moparx  Offline
adhesive silicone is different than RTV, correct ?
so no moisture needed to cure, correct ?
beer
Re: 440 Rear Main Seal [Re: Cab_Burge] #2973071
10/11/21 03:39 PM
10/11/21 03:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Unless you live in an environmental chamber where the humidity is 0%, there is alway some moisture in the air scope
So you're right (it needs exposure to air) but for the wrong reason (it's not the air, it's the water in the air) whistling
Re: 440 Rear Main Seal [Re: John_Kunkel] #2973074
10/11/21 03:44 PM
10/11/21 03:44 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
thumbs Water and pipe cleaners work good!
Re: 440 Rear Main Seal [Re: John_Kunkel] #2973261
10/12/21 01:01 AM
10/12/21 01:01 AM
Boise
Boise
Great info on the pipe cleaner. I'll do this on the next build. FWIW, RTV=Room Temperature Vulcanizing.
Re: 440 Rear Main Seal [Re: Moparteacher] #2973395
10/12/21 12:36 PM
10/12/21 12:36 PM
moparx Offline
moparx  Offline
how does adhesive silicone cure ? internally out/absent of air and humidity, or externally in/exposure to air and humidity ?
beer
Re: 440 Rear Main Seal [Re: moparx] #2973402
10/12/21 12:45 PM
10/12/21 12:45 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Humidity and temperature, normally 24 hr cure time.
