Re: 2000 Ram Fog Lamps
[Re: 70sixpkrt]
#2972228
10/08/21 10:00 PM
10/08/21 10:00 PM
Posts: 120 North Seattle, Washington. USA
U code RR
Do you have a Sport with the factory fog lights? I have a 99 Sport and the fog lights inside reflector started to fade and get dingy so I replaced them with OEM style from the after market. Looked identical and were inexpensive. Simple job. Can't believe the difference in brightness.
When seconds count...
The Police are only minutes away.
Smith and Wesson are your friends.
[Re: 70sixpkrt]
#2972483
10/09/21 07:33 PM
10/09/21 07:33 PM
Posts: 8,494 Candler,NC / Myrtle Beach, SC
JDMopar
I just replaced a factory fog lamp bulb on our 2004 Dakota, and got it at NAPA. It was like $8.00 for the bulb. I need to go back and get one for the other side, because the new one is so much brighter. When you pull the bulb out, it will have a number on it, and you can just match it up off the rack at the parts store.
[Re: JDMopar]
#2972621
10/10/21 10:24 AM
10/10/21 10:24 AM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
I just replaced a factory fog lamp bulb on our 2004 Dakota, and got it at NAPA. It was like $8.00 for the bulb. I need to go back and get one for the other side, because the new one is so much brighter. When you pull the bulb out, it will have a number on it, and you can just match it up off the rack at the parts store. I need the whole fog light assembly. Mine is all faded.
