Re: Best or should I say easy way to get into wife's laptop?
[Re: 340SIX]
#2972112
10/08/21 04:34 PM
10/08/21 04:34 PM
Posts: 9,507 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Make and actual model will help.
The old way was to replace the chip on the board, but now there are many hacks to get them to boot up but need what it really is.
Is the the bios password or will it boot and its a windows password she cant get.
And is there info shes trying to retrieve or ?
If its a windows password the easy way is simply use the restore discs.
STOP POTATO HATE!
[Re: 340SIX]
#2972128
10/08/21 05:19 PM
10/08/21 05:19 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Easiest cheapest way is to burn a linux live CD, or make a bootable USB from a linux distro, boot into the live session, go into the Windows file system with this path
C:\Windows\System32\config\sam
Find her account name and delete the password.
Remove the live CD / USB, reboot into windows and she can access her account without a password. First thing to do is assign a password she'll remember and done.
In linux speak C drive is going to be sd* where * is a variable depending on type of hard drive.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#2972242
10/08/21 10:28 PM
10/08/21 10:28 PM
3hundred
Colleyville
Found my CD! Trinity Rescue Kit This one linky is dedicated to password recovery only and as I recall, it's VERY easy to use. Just download it to bootable media for the laptop, boot from it and follow directions. After you boot Trinity Rescue Kit, you should see the following screen. Scroll down to the “Windows password resetting” option, then hit Enter. Next select the “Winpass prompts for username first” option. TRK will ask you the username for the account for which you want to reset the password.
[Re: 3hundred]
#2972333
10/09/21 10:03 AM
10/09/21 10:03 AM
Andrewh
Found my CD! Trinity Rescue Kit This one linky is dedicated to password recovery only and as I recall, it's VERY easy to use. Just download it to bootable media for the laptop, boot from it and follow directions. After you boot Trinity Rescue Kit, you should see the following screen. Scroll down to the “Windows password resetting” option, then hit Enter. Next select the “Winpass prompts for username first” option. TRK will ask you the username for the account for which you want to reset the password. none of the links to download it works. looks like they got taken down or something.
[Re: Andrewh]
#2972377
10/09/21 11:56 AM
10/09/21 11:56 AM
3hundred
Colleyville
Found my CD! Trinity Rescue Kit This one linky is dedicated to password recovery only and as I recall, it's VERY easy to use. Just download it to bootable media for the laptop, boot from it and follow directions. After you boot Trinity Rescue Kit, you should see the following screen. Scroll down to the “Windows password resetting” option, then hit Enter. Next select the “Winpass prompts for username first” option. TRK will ask you the username for the account for which you want to reset the password. none of the links to download it works. looks like they got taken down or something. Found it! Download success! https://www.majorgeeks.com/files/details/trinity_rescue_kit.html Version 3.4 claims to be for Win7, the last post @ chntpw is dated 2015, the latest file in ver 3.4 is dated 2011. I believe secure boot came out several years later, you may have to disable UEFI / secure boot to get it to boot. I haven't had need of it in a decade or so, was surprised and kinda excited to find my ver 3.3 CD.
[Re: 3hundred]
#2972406
10/09/21 02:06 PM
10/09/21 02:06 PM
3hundred
Colleyville
Okay, I've successfully reset my local administrator account password on an older (2010, former server, dual processor) Win10 computer. It's a bit geekier than I recall, read the menu choices carefully. If you run into troubles, ask.
Basically, if you're used to using a number pad on the right side of the keyboard, turn on number lock or use the number keys above the letters Run from RAM, choice 2 Mount all drives Remember the name of the user account you want to reset, case sensitive, it'll ask you which account you want to blank the password When it came time to reboot, mine didn't seem to want to, since my patience level is patience hell, let's kill something, I forced reboot with the power button Lastly, Windows will complain when it restarts it wants a password.
HTH
