440 Rear Main Seal
#2971790
10/07/21 05:52 PM
10/07/21 05:52 PM
Posts: 16,929 NC
440Jim
NC
I was going through my spare parts, and found two Mopar Performance rear main seal kits for a 440 big block. P4271961, They have the regular black rubber lip seals, and red rubber side seals. Just like this kit on Mancini Mancini rear main seal kit (LINK)Do these hollow red rubber side seals work well?
Re: 440 Rear Main Seal
[Re: jwb123]
#2972023
10/08/21 12:07 PM
10/08/21 12:07 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
YES... install the pin ... its needed to expand the rubber side seals/
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: jwb123]
#2972024
10/08/21 12:10 PM
10/08/21 12:10 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
I only use the Fel-Pro Vito rear main seals, part number 2947 and cost $25-$30.
Taken from 440Source "They have a much greater resistance to high temperatures than standard rubber. It also doesn't have a tendency to dry out and shrink over time."
I also do not use the side seals, I use black RTV, either Permatex Ultra Black or Right Stuff. I clean the surfaces, fill in the sides and then installed the seal and then fill in the back cavity with RTV.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: dvw]
#2972271
10/09/21 12:25 AM
10/09/21 12:25 AM
Posts: 712 California
BigDaddy440
California
I have done it both ways with big block mopars, but my last few I've been using Permatex Ultra Black on the sides with success. It does depend on the RMS retainer you're using. Some aftermarket units use two thin rubber seals. Those channels would be too hard to fill with RTV from the top. My most recent build was a Ford FE Big Block which has the same type of side seal / pin system (as the topic starter pictured) and I again filled the void with the Ultra Black. It works very well.
The trick is using the supplied screw on applicator that comes with the Permatex. You get the nose of the applicator in side the void and squeeze hard filling the void completely. I use one of the intended rubber side seals to push the Ultra Black down and pack it in the void. Then I top it off until it's oozing out the top and wipe flush.
Ultra Black takes a while to dry when thick, so I recommend letting it set up for a few days before adding oil / starting the engine.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: Mopar Mitch]
#2972310
10/09/21 08:55 AM
10/09/21 08:55 AM
Posts: 3,089 Michigan
A727Tflite
YES... install the pin ... its needed to expand the rubber side seals/ Anyone have a picture of the pin mentioned here?
[Re: A727Tflite]
#2972489
10/09/21 07:52 PM
10/09/21 07:52 PM
Posts: 257 Alberta
440_Offroader
Alberta
YES... install the pin ... its needed to expand the rubber side seals/ Anyone have a picture of the pin mentioned here? X2, never seen the mentioned pin. Sounds like a good idea though....
[Re: Moparteacher]
#2972729
10/10/21 03:38 PM
10/10/21 03:38 PM
Posts: 25,925 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I fill in the sides with RTV and then slide in a piece of copper rod to expand the RTV. Trim flush. A water-dampened pipe cleaner to expand the RTV works better. RTV sets up by exposure to moisture.
[Re: John_Kunkel]
#2972735
10/10/21 03:53 PM
10/10/21 03:53 PM
Mopar Mitch
This is exactly correct!!! RTV must have humidity to cure.
Mopar Mitch
[Re: John_Kunkel]
#2973074
10/11/21 03:44 PM
10/11/21 03:44 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
I fill in the sides with RTV and then slide in a piece of copper rod to expand the RTV. Trim flush. A water-dampened pipe cleaner to expand the RTV works better. RTV sets up by exposure to moisture. Water and pipe cleaners work good!
[Re: John_Kunkel]
#2973261
10/12/21 01:01 AM
10/12/21 01:01 AM
Posts: 610 Boise
Moparteacher
Boise
I fill in the sides with RTV and then slide in a piece of copper rod to expand the RTV. Trim flush. A water-dampened pipe cleaner to expand the RTV works better. RTV sets up by exposure to moisture. Great info on the pipe cleaner. I'll do this on the next build. FWIW, RTV=Room Temperature Vulcanizing.
