Page 3 of 3 1 2 3
Re: Hemi oil pressure at idle? [Re: cudaman1969] #2970912
10/05/21 12:57 PM
10/05/21 12:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by cudaman1969
Any and all aftermarket pumps where copy’s of the factory pump.
Not an accurate statement. Both Dailey and Wescott pumps only similarity to stock stuff is they bolt to the same place. Otherwise they are wildly different in design(think BBC pump, or roots style rotors in Daileys case).
Re: Hemi oil pressure at idle? [Re: BSB67] #2971356
10/06/21 02:38 PM
10/06/21 02:38 PM
Queen Creek, AZ
Buster Offline
Buster  Offline
Queen Creek, AZ
Thanks to all who have replied, lots of knowledge here!
In reply to various questions, I'm using VR1 20w50 and a K&N filter (I cut open the PH8A that was on it and didn't find any metal, babbit, etc.) It has a 6 quart pan stamped 854, it's blue and has a decent size dent in the bottom. Can't tell you exact RPM at cruise, trying to get my eBay Sun SuperTach II to work correctly. When I put 12V to it the motor stalls, I'll do another thread about that. Anyway, estimated RPM at cruise 3000 give or take, I get just under 30 PSI in 4th at 50 mph when it's fully warm. (It's got 3:54's, you math wizards can work it if you want to). It gets 60 PSI when I start it cold, it gradually drops as it warms up to the point where it only gets 10 PSI at idle. PSI goes up as RPM does, a blip of the throttle gets 25-30. I honestly didn't think to check the bypass spring. Intended use: cruising and car shows, I want it to be a street car that I can drive for 2-3 hours straight, city, highway, whatever.
Very cool idea to install the HV oil pump by taking the cover off to slip it in and then reassemble, I might try that. But- I don't think there's any doubt I need to pull the pan.
I'm taking another car to a show this weekend, then I have travel plans to drive the Natchez trace in a motor home with li'l sis and her husband, may be a couple of weeks 'til I get serious again. I'll let you all know.
Thanks again, you guys are really helpful!
Re: Hemi oil pressure at idle? [Re: Buster] #2971506
10/06/21 08:39 PM
10/06/21 08:39 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Let me know if you need a hand. I’m car sitting one of our C&C friends. If we can get him to pick up his car, we can install the pump at my house.
Re: Hemi oil pressure at idle? [Re: gsmopar] #2971588
10/07/21 12:21 AM
10/07/21 12:21 AM
Queen Creek, AZ
Buster Offline
Buster  Offline
Queen Creek, AZ
Awesome, thanks, I might just do that.
Re: Hemi oil pressure at idle? [Re: Al_Alguire] #2971695
10/07/21 01:37 PM
10/07/21 01:37 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Should of been more specific, cast iron stock stuff.
Re: Hemi oil pressure at idle? [Re: cudaman1969] #2971771
10/07/21 05:02 PM
10/07/21 05:02 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Many years ago Brother Inlaw had his Hemi Motor rebuilt from his 1969 RT Coronet. Put it in and never had good Oil Pressure. 35-40 max maybe 11 lbs idle. Tried a pump, tried a shim finally pulled the motor took off the pan, I wanted to see if the clearance between the PU and Pan and if it was too close and blocking oil to the pick up. It was fine. Took a look at the pan rail and saw the 1.5M on the rail. I said to him you got the parts list this builder used on the motor. He had put standard Bearings in the motor. The motor from the factory was all read down 1.5. The clearances on the mains were to great. Pulled a 1010 crank out of the garage and off to the builder and told him to pull a main cap and and start measuring. Yes the crank was down and he looked at us with a blank stare. Pulled the crank out and told him to find the sweet spot to putt the crank out and use the 1010 crank and new bearings and rod bolts. Motor has been together since the 80s with out a oil pressure problem. In my street motor that is about 612 HP on start up it read over 100 lbs cold. The race motor is over 100 lbs at RPM. I use 40 weight. So pro mod motors run 200+ lbs and have a 135 shut off but that is a completely different oil system. Stock pans are not big enough if you are going to use it hard. I never run hemi without a 10 or more quart pan on it unless it is some kind of trailer queen restoration.
1971 HEMI E BODY REGISTRY
Re: Hemi oil pressure at idle? [Re: hemicar1971] #2971859
10/07/21 08:42 PM
10/07/21 08:42 PM
Every street and NHRA legal stocker 426 Hemi motors I've work on and raced always went faster and made more power with 10W30 than they did with 20W50Wt oil shruggy
Shorting up the bypass spring so the motors would have 70 Lbs. pressure with hot oil at 7000 RPM made more power than 80+ lbs. did also with the same oil temps. and RPM scope
10 lbs. per 1000 RPM with hot oil is a good scale to use up
I can remember when the NHRA Comp Eliminator races started using zero weight synthetic oils and changing it after every run to get .0015 ET gain shock scope
Re: Hemi oil pressure at idle? [Re: hemicar1971] #2971869
10/07/21 09:02 PM
10/07/21 09:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The pickup screen must be at least 1/4" away from the pan bottom, or it will restrict suction.
3/8" is preferred, but some pans are not deep enough to have enough oil volume above the pickup to keep it submerged no matter what the car does (wheelie, hard braking, spin out). If the oil level in the pan was a foot deep, 3" from the pickup to the pan would be safe.
Boffin Emeritus
Re: Hemi oil pressure at idle? [Re: polyspheric] #2971946
10/08/21 08:44 AM
10/08/21 08:44 AM
VA
dragon slayer Offline
VA
What is funny about this; is the Service manual does actually say touch the pan. The way the pickup head is built even if touching pan there is access for flow. Most builders do recommend a gap though.
Re: Hemi oil pressure at idle? [Re: dragon slayer] #2971956
10/08/21 09:36 AM
10/08/21 09:36 AM
A727Tflite Offline
A727Tflite  Offline
The pickups on Chrysler products were designed to contact the pan to keep them from breaking due to vibration.
You are correct, the pickup basket is designed to provide for flow when the basket is in contact.
Re: Hemi oil pressure at idle? [Re: A727Tflite] #2971988
10/08/21 10:43 AM
10/08/21 10:43 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Isn’t that’s what that shield on the pickup is for, to touch the pan? Then the screen is up above about the 1/4 that was mentioned.
Re: Hemi oil pressure at idle? [Re: cudaman1969] #2972082
10/08/21 02:47 PM
10/08/21 02:47 PM
A727Tflite Offline
A727Tflite  Offline
You are correct.
Re: Hemi oil pressure at idle? [Re: A727Tflite] #3035957
04/22/22 10:53 AM
04/22/22 10:53 AM
Queen Creek, AZ
Buster Offline
Buster  Offline
Queen Creek, AZ
Ok, long past time for an update. Took more than a while to get to this, but here's what I found. Pulled the pan and the pickup was beat up, crooked corresponding to the dent in the bottom of the (non-original) pan,and had some junk on the screen. Glad I didn't just put a HV oil pump on and cross my fingers, but now suspicious of what else I'd find. Dropped the windage tray and planned to Plastigauge some bearings. I'd heard that #7 rod bearing was a common failure (less oil at the rear of the engine?) so I pulled the cap. Bearing pitted and scored, crank scored enough that it catches on my fingernail. Bummer. Took the Plastigauge back to the parts store. It's gotta come out, now it's a much bigger project. Oh well, I'm disappointed but not surprised. This car has a race history and then sat for 27 years before seeing the light of day again. This is the price for super low miles- neglect is worse than use.
Thanks to everyone who chimed in, once I get it out and pick a machine shop/builder I'll let you know how it goes.
Re: Hemi oil pressure at idle? [Re: Buster] #3036035
04/22/22 01:37 PM
04/22/22 01:37 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Look on the bright side. You found potential problems before you could see the interior of the engine from the exterior.
Re: Hemi oil pressure at idle? [Re: 6PakBee] #3036067
04/22/22 03:30 PM
04/22/22 03:30 PM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Well it's a good thing that you found the problem so you can correct it before you did major damage to the engine. Thanks for updating us on this.
Maybe now you want to consider a stroke or crank, some modern rods, and lightweight pistons?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi oil pressure at idle? [Re: Buster] #3036123
04/22/22 08:30 PM
04/22/22 08:30 PM
Someone in the past has made the rod bolt score the crank journal, bad mistake tsk I've seen and heard of guys at the races use a knife wet fine finish stone to remove the high spots off of the ridges from the bolt marks and have no problems with new bearings on those patched up journals work shruggy If you can feel it now you may want to try that ,if you do that please make sure it is very clean and oiled well before installing the new rod bearings on all the journals wrench uptwocents
Re: Hemi oil pressure at idle? [Re: Cab_Burge] #3036254
04/23/22 10:18 AM
04/23/22 10:18 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I agree with Cab, I would try to clean up that journal and run it.
You should be able to judge once you get into it, but from the pic, I would try first.
Joe
Re: Hemi oil pressure at idle? [Re: jlatessa] #3036583
04/24/22 12:59 PM
04/24/22 12:59 PM
Queen Creek, AZ
Buster Offline
Buster  Offline
Queen Creek, AZ
Appreciate the input, and to Cab's point, you can see the marks on the crank from the rod bolt(s). It's got a race history, and I was told by the guy who owned it after the racer that the motor spun a rod bearing. It's obviously been apart before (the rod caps are ground for balancing, not the oil pan). Likely it was repaired/assembled in a hurry and never corrected.
I nicked the crank with a rod bolt on the first engine I ever built, the machinist (way back, racer from my hometown and former partner of Jon Kaase before Dyno Don fame) said to carefully use a stone to smooth the edges of the crescent-shaped gouge and run it. I did just that and the 289 has been together since 1977 with no related issues.
But- seeing the pits on the bearing makes me think that the oil got acidic while it slept for 27 years and ate the bearings. I didn't pull any other caps but I'd expect to see the same thing. I think the safe play is to tear it down.
Oh yeah, I should have done this long ago but it just occured to me- I have a copy of the Plymouth Service Bulletin # 66-45 dated January 14 1966. Under Engine Lubrication it says Oil Pump Operating Pressure @ 1000 RPM should be 45-65 lbs. So there's the factory spec for 1966 Hemi oil pressure.
Re: Hemi oil pressure at idle? [Re: Buster] #3036585
04/24/22 01:01 PM
04/24/22 01:01 PM
Queen Creek, AZ
Buster Offline
Buster  Offline
Queen Creek, AZ
Meant to say not the original oil pan.
Page 3 of 3 1 2 3
