Challenger Script, 71 tailpanel same as fender with studs?
#2971237
10/06/21 08:12 AM
10/06/21 08:12 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Like the title says. Is the 1971 Challenger tail panel script emblem the same as the studded emblems used on fenders?
Does anyone know how many versions there were on the 70-74? From what I see on ebay it looks like there were flat adhesive replacement script, studded flat fender script, thick 70 grill script, really thick 72-74 grill script. Any others?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Challenger Script, 71 tailpanel same as fender with studs?
[Re: Michael Ecks]
#2971418
10/06/21 04:44 PM
10/06/21 04:44 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
72-74 Challenger 1/4 panel script is adhesive backed. I believe the 72-74 grill emblem is tapered on the back side to fit the grill. Haven't looked at one for awhile but I'm pretty sure it's tapered.
Looks like the 71 tail panel script had the pin moved because it was too close to the tail panel seam.
[Re: 6bblgt]
#2971555
10/06/21 10:14 PM
10/06/21 10:14 PM
Michael Ecks
Columbus, GA
Thanks. Just the information I needed.
[Re: burdar]
#2971635
10/07/21 09:52 AM
10/07/21 09:52 AM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
Looks like the 71 tail panel script had the pin moved because it was too close to the tail panel seam. You are correct, it is tapered, and the letters are very thick.
