Small block 727 inspection covers #2971001
10/05/21 03:41 PM
10/05/21 03:41 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
I have two different inspection covers that fit on a small block 727. One is a one piece full cover. The other is two pieces, the large cover with the little piece at the bottom center. Was there a change from one to the other in a specific year?
Re: Small block 727 inspection covers [Re: 6PAX] #2971125
10/05/21 08:35 PM
10/05/21 08:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The 2 piece cover with the small opening was to drain the torque converter when servicing the trans. not sure what year the did away with it. My guess would be in the 70's but not sure on that twocents beer
Re: Small block 727 inspection covers [Re: TJP] #2971173
10/05/21 10:20 PM
10/05/21 10:20 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
My ‘72 has the galvanized 2-piece cover...
China is the enemy.
Re: Small block 727 inspection covers [Re: 1972CudaV21] #2971263
10/06/21 10:01 AM
10/06/21 10:01 AM
NY
twodoorpost Offline
twodoorpost  Offline
NY
The factory parts book show the 2 piece shield until 1979 and 1 piece for 1980 and newer. This is for both the 904 and 727 trans.
Re: Small block 727 inspection covers [Re: twodoorpost] #2971307
10/06/21 12:20 PM
10/06/21 12:20 PM
Detroit area
6PAX Offline OP
6PAX  Offline OP
Detroit area
Thanks everyone.
Re: Small block 727 inspection covers [Re: 6PAX] #2971581
10/06/21 11:34 PM
10/06/21 11:34 PM
5thAve Offline
5thAve  Offline
The drain and that two piece cover went away when they started using lock up torque converters. I thought I read somewhere years ago that it happened in 79 but it was somewhere in 78-79-80.
