Vintage accel plug/catalog ?? #2970195
10/04/21 08:04 AM
10/04/21 08:04 AM
VA
dragon slayer Offline OP
VA
Anyone have a vintage accel plug catalog or know what the 241871 plugs are for heat range wise. Thanks,
Re: Vintage accel plug/catalog ?? [Re: dragon slayer] #2970246
10/04/21 09:44 AM
10/04/21 09:44 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
try calling accel wink
I may have a catalog but would take some time to find it. Might also check ebay
The again for the cost of a set of plugs is it worth the effort ? beer
Re: Vintage accel plug/catalog ?? [Re: TJP] #2970266
10/04/21 10:46 AM
10/04/21 10:46 AM
VA
VA
I did the google thing but did not find anything and the accel web was worthless too. Your not sugguesting just throw them away are you blush I know they would work hemi or small block, but knowing heat range would be helpful. Newer accel catalog just doesn't address it, or the cross reference I have seen. Accel changed hands too many times I guess.
Re: Vintage accel plug/catalog ?? [Re: dragon slayer] #2970572
10/04/21 09:23 PM
10/04/21 09:23 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Not necessarily but maybe put them aside until you can find the info. in about 2-3 ,months I'll have more time to look for the catalog if I have one? but right now I don't, I'm working 7 days a week and get an hour or two to myself. message me in a couple of months if you'd like beer
Re: Vintage accel plug/catalog ?? [Re: dragon slayer] #2970608
10/04/21 11:02 PM
10/04/21 11:02 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
what is the number printed on the plug ?
Re: Vintage accel plug/catalog ?? [Re: calrobb2000] #2971503
10/06/21 08:28 PM
10/06/21 08:28 PM
VA
VA
insulator 434, plug metal casing has the last 5 of the plug number.
So we did find a vintage catalog. Here is the 6 digit part number chart from the book.
First: 2 Standard plug, 3 Resistor plug
2nd: Thread size 1=10mm, 2=12mm, 4=14mm, 8=18mm
3rd: 1=gasket, 2=taper
4th: Heat range. 9=Hottest, 0= coldest
5th: Reach: 1=1/4", 2=3/8", 456.....7=3/4" and 8=3/4" with 3/8th thread
6th Electrode: 1=Regular; 2=Extended, 3=Multi-Reg, 4=Multi-Extend, 5= Platnium, 6= Recessed
So this is a regular tipped version of the hemi or small block, in a pretty hot range. Champion 16 equivalent.
The necessary plug would be a 241X72. With X being heat range.
