what covers fit over RBRE rocker gear? #2969446
10/01/21 09:33 PM
10/01/21 09:33 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Will these fit? using stage 5 heads
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2969491
10/02/21 12:43 AM
10/02/21 12:43 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Should work no problem. Those center breathers can be tough to find.
Todd
Re: what covers fit over RBRE rocker gear? [Re: sasquatch] #2969519
10/02/21 07:58 AM
10/02/21 07:58 AM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
Yes, those will clear. As mentioned the breathers are hard and expensive if you find them. I have a set of those Mopar Performance covers also. I went with a set of Indy covers that has a shocker tower relief in the passenger cover which helps on my car if you look closely in the engine on the stand picture. They clear my RBRE rocker system.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: what covers fit over RBRE rocker gear? [Re: 6PKRTSE] #2969553
10/02/21 09:35 AM
10/02/21 09:35 AM
Mt Morris Michigan
Mt Morris Michigan
I didn't know that a cover was available with a relief in it. Were those designed with the A body in mind? If i could avoid modifying the shock tower I will be ecstatic.
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2969557
10/02/21 09:41 AM
10/02/21 09:41 AM
Mt Morris Michigan
Mt Morris Michigan
These look nice, but i dont think they have relief.
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2969671
10/02/21 04:17 PM
10/02/21 04:17 PM
moparx Online content
moparx  Online Content
what makes the breathers hard to find ? i know how almost everything a guy want's nowadays is back ordered, but what makes those breathers so different than others ?
i am gen 2 hemi ignorant, so please don't beat on me too hard ! spank
i'm just trying to learn new stuff.
beer
Re: what covers fit over RBRE rocker gear? [Re: moparx] #2969686
10/02/21 04:53 PM
10/02/21 04:53 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
I have the same Indy valve covers as 6PKRT, but mine had to be milled inside to clear.
[Linked Image]Untitled by Greg Ault, on Flickr
Re: what covers fit over RBRE rocker gear? [Re: moparx] #2969692
10/02/21 05:35 PM
10/02/21 05:35 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
beer
They were sold separately from the valve covers. I see a lot more valve covers for sale than I do breathers.
These are K/B valve covers and breathers . twocents
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: what covers fit over RBRE rocker gear? [Re: sasquatch] #2969736
10/02/21 08:00 PM
10/02/21 08:00 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Todd
For the breathers, see https://www.goodvibesracing.com/Burndown_Tubes.htm ... I purchased a set of C-7197. They are pretty tall and pretty expensive ... but we're talking Hemi here so you need to bring Hundred dollar bills to buy even small parts!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: what covers fit over RBRE rocker gear? [Re: rumblefish72] #2969737
10/02/21 08:02 PM
10/02/21 08:02 PM
Motor City
Motor City
I was going to suggest that place, but I couldn't think of their name.
Re: what covers fit over RBRE rocker gear? [Re: 6PKRTSE] #2969748
10/02/21 08:26 PM
10/02/21 08:26 PM
I keep taking my Prevagen wink
It took me some time to find them at Good Vibrations Motorsports. These type breathers show up on eBay and RacingJunk every so often but they are always $200 - $300 or more for a pair.
Re: what covers fit over RBRE rocker gear? [Re: rumblefish72] #2969767
10/02/21 09:04 PM
10/02/21 09:04 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for the info on the center breathers guys should i go that route. Can anyone point me to all the companies making the covers with the relief for the shock tower? I assume that relief is ment for A body cars which would be a big time saver since this hemi is going in an A body.
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2969905
10/03/21 09:52 AM
10/03/21 09:52 AM
Motor City
Motor City
As I mentioned above mine are from Indy.
Re: what covers fit over RBRE rocker gear? [Re: 6PKRTSE] #2969906
10/03/21 10:05 AM
10/03/21 10:05 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Thanks for the Good Vibrations Racing tip I will have to remember that. There is a guy who makes them out in Nevada whose name I would have to dig up. The breathers were sold by Mopar Performance but like most things they no longer do. Companies like Mooneyes sells breathers like them but the bolt spacing is usually not the same as a lot of these hemi covers use. Todd
Re: what covers fit over RBRE rocker gear? [Re: sasquatch] #2969910
10/03/21 10:20 AM
10/03/21 10:20 AM
Mt Morris Michigan
Mt Morris Michigan
If you have time, post it up. So far Indy is the only seller of the notched cover that i have found.
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2970204
10/04/21 08:25 AM
10/04/21 08:25 AM
an8sec70cuda Offline
AFAIK Indy is the only one that makes the notched covers. Mine are Indys, but aren't the notched ones. Don't think they made them when I got mine. I highly recommend the notched ones, lol.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: what covers fit over RBRE rocker gear? [Re: an8sec70cuda] #2970208
10/04/21 08:32 AM
10/04/21 08:32 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I used these - they fit - they are the 64-65 re-pops - I use the tall felpro gasket to get a little extra clearance
Re: what covers fit over RBRE rocker gear? [Re: DoubleD] #2970229
10/04/21 08:58 AM
10/04/21 08:58 AM
Motor City
Motor City
NICE. That picture is better than Viagra.
Re: what covers fit over RBRE rocker gear? [Re: sasquatch] #2970232
10/04/21 09:01 AM
10/04/21 09:01 AM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
Todd
Todd, I have a set if you know anyone needing them?
Greg
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: what covers fit over RBRE rocker gear? [Re: mopar dave] #2970234
10/04/21 09:03 AM
10/04/21 09:03 AM
MoparJunkie Offline
MoparJunkie  Offline
I have a set of those valve covers without the 572 on them. They are newly used with the breathers. PM for pics or info.
Greg
