Attaching sub frame connectors ? #296786
04/22/09 08:12 PM
04/22/09 08:12 PM
Haslett, MI
7DRRunner Offline OP
Haslett, MI
Have you added sub frame connectors ?
How are sub frame connectors attached ?
I was reading thru the Hotchkis site, and they say
"Does not require cutting or modifying the floor"
Welded ?
http://www.hotchkis.net/subframe_connectors_mopar_bbody_.html
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: Attaching sub frame connectors ? [Re: 7DRRunner] #296787
04/22/09 08:23 PM
04/22/09 08:23 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Weld them on.
Some places make bolt-on versions, but they don't work as well - the holes become elongated and some of the benefit is lost.
Re: Attaching sub frame connectors ? [Re: 7DRRunner] #296788
04/22/09 10:41 PM
04/22/09 10:41 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Weld them on you won't be sorry. I'm cutting mine thru the floor and adding all the strength I can.
Re: Attaching sub frame connectors ? [Re: moparpollack] #296789
04/22/09 11:31 PM
04/22/09 11:31 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
ya but what do you do with the torque boxes that cover the rear frame rails?
Re: Attaching sub frame connectors ? [Re: aarcuda] #296790
04/22/09 11:33 PM
04/22/09 11:33 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Slice one or the other. I think on mine we cut the frame connectors where the torque boxes were.
Re: Attaching sub frame connectors ? [Re: 7DRRunner] #296791
04/23/09 01:08 AM
04/23/09 01:08 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Welded ?
Download and read the "Installation Instructions" link on the link you attached...It's kinda cool actually, and they have some interesting and pricey items to go along with this too.
http://www.hotchkis.net/_uploaded_files/4010instructions846930886file.pdf
