Any Race trucks in the forum? Any tips on building one? #2965523
09/19/21 05:18 PM
09/19/21 05:18 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
With my future build still mostly on paper, I decided to look at some ideas for when I do start building my truck. Though I know there are hundreds of views/posts here, I can't say I have ever seen anything really on pickup trucks unless it's a tow vehicle. Trying to get some ideas for chassis, cages, rear-ends, wheel clearance, etc from the racers/builders. Would enjoy seeing what the members have built over the years. Got anything to share?
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2965564
09/19/21 09:04 PM
09/19/21 09:04 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Quite a few on here... What level of performance you looking for? Below are my current truck, A truck I built in 1986 w/a 440 then Upgraded in 1988 to a Hemi and then full tube chassis w a Hemi in 1989.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Any Race trucks in the forum? Any tips on building one? [Re: W.I.N. Racing] #2965591
09/19/21 10:06 PM
09/19/21 10:06 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Oh dang, those are nice AND it looks like your ready to boogie! About what I want to build is a 1970's Ramcharger, kinda street/strip truck. Might try to find a stepside again down the road if It's more feasible to build. Not sure how much of the stock frame is good, so maybe boxing and cage might work. The stance on that last pic is crazy!
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2965622
09/20/21 12:41 AM
09/20/21 12:41 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
This one will be totally on its way soon. Transforming from show car to racecar. 6.0 cert moly chassis all steel and even will retain the power windows.
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2965727
09/20/21 12:41 PM
09/20/21 12:41 PM
Byron, NY
Byron, NY
The first mods I did to make the '79 a "Drag Truck" was to remove the rear axle and springs and spring hangers. Mounted some B Body front and rear spring mounts to the bottom flange of the frame rail using the B body springs for placement and ultimately suspension. Then I used a B body Dana 60 (5.13 gears) mounted on top of the springs with the perches re positioned for spring with and pinion angle. Cut the box tubs for tire clearance to the frame rail and a centered 14"wide wheel put some 32x14 slicks . Left the 6cyl springs in the front and removed any and all unnecessary stuff from under the hood. Using a 76 smog 440 with a Direct connection .509 hyd cam, Holley Street Dominator intake, 800 Holley and Headman Truck headers. the trans was a 727 with a homemade reverse manual VB and the torque converter from behind the smog 440 it ran a best of 13.09. Put a warmed up 426 ( increased comp to 12-1, .650 lift flat tappet cam, tunnel ram with a pair of 660's ) in it with a set of slightly modified A body Hemi headers and better converter, it would run 11.50's but need a roll bar so usually just dialed slower. Both of these combinations were street-able and were often driven silks and all around town.
I actually have a ’84 2wd Ramcharger sitting as a “ I got nothing to work on “ project. The plan is to take the roof and rear window off a PU and graft it to the RC to make it an extra short wb (108 vs 118) Uni body PU. Then do up a simple tube chassis out of the parts that have accumulated around here … just to stay busy, If Im lucky I'd be able to sell it and break even on parts.
'60 Willys CJ5
Re: Any Race trucks in the forum? Any tips on building one? [Re: W.I.N. Racing] #2965795
09/20/21 03:44 PM
09/20/21 03:44 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
92 D150 I am the original owner not fast 15s but goes rounds and Wins Eliminators ...5.2 ( 318 ) Magnum , 518 trans with shift kit and redone lock up converter by Ultimate, 4.10 sure grip rear, headers, ram air kit, computer, drag radials, traction bars and Rancho shocks goes 2.0s in 60 ft best e.t. 15.04... I also show it and its Won a few awards that way also..dual purpose " Show and Go"
303C560F-03C6-4751-AA3C-5F7A9BAC4283.jpegC51E21D8-69BB-4767-85BD-A1F6F7D2ECC7.jpeg0FB15299-9537-4EDF-B9E3-8C387935B007.jpeg
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Any Race trucks in the forum? Any tips on building one? [Re: 11secdart] #2965802
09/20/21 04:17 PM
09/20/21 04:17 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Had a ProStreet one I raced occasionally....Was a lot of fun...
360 ci
4.56 gears
A518 trans
3240lbs
Re: Any Race trucks in the forum? Any tips on building one? [Re: Dragula] #2966285
09/22/21 10:41 AM
09/22/21 10:41 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Love the pics and info guys!
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2966424
09/22/21 05:40 PM
09/22/21 05:40 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Last weekend
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2966547
09/23/21 03:54 AM
09/23/21 03:54 AM
est
huimerind Offline
huimerind  Offline
est
Re: Any Race trucks in the forum? Any tips on building one? [Re: huimerind] #2966552
09/23/21 07:11 AM
09/23/21 07:11 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Wow!!! Cool!!!
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2966578
09/23/21 08:34 AM
09/23/21 08:34 AM
MD
1965fish Offline
1965fish  Offline
MD
2001 Dakota 10.65 at 126 mph.
394 CI small block LA.
904 trans
8 3/4 w/ 4.56
Power windows, door locks, mirrors.
Full interior
3750 with 180 lb driver.
1965 Plymouth Barracuda Formula S
1965 Plymouth Valiant 200 Convertible
1965 Plymouth Valiant 200 Station wagon 408 6.52 @ 104
2001 Dodge Dakota 394 6.63 @ 103 1/8 mile 10.64 @ 123 1/4 mile
1965 Plymouth Valiant Signet 2DR HT
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2966616
09/23/21 09:57 AM
09/23/21 09:57 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I like the idea of a 70's Ramcharger and build it as an "All wheel drive" vehicle instead of just the common rear wheel drive setup most drag cars use.
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2966735
09/23/21 04:21 PM
09/23/21 04:21 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Not nearly as fast as these on this post, but it is very streetable with a mild 392 Magnum based motor, 9.5:1 compression, .520 hydraulic roller, 3.55 gear.
Re: Any Race trucks in the forum? Any tips on building one? [Re: migsBIG] #2967141
09/24/21 08:45 PM
09/24/21 08:45 PM
est
huimerind Offline
huimerind  Offline
est
Re: Any Race trucks in the forum? Any tips on building one? [Re: huimerind] #2967325
09/25/21 03:11 PM
09/25/21 03:11 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Diggin the Dakotas!
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: Any Race trucks in the forum? Any tips on building one? [Re: 11secdart] #2967440
09/26/21 05:18 AM
09/26/21 05:18 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Originally Posted by 11secdart
Diggin the Dakotas!
iagree
Re: Any Race trucks in the forum? Any tips on building one? [Re: huimerind] #2967573
09/26/21 05:36 PM
09/26/21 05:36 PM
Originally Posted by huimerind
Come man, everybody knows pickups can't do wheelies, this must be trick photography whistling grin up
That picture reminds me of northern Germany way back when I was over there beer
Re: Any Race trucks in the forum? Any tips on building one? [Re: Cab_Burge] #2969372
10/01/21 06:42 PM
10/01/21 06:42 PM
est
huimerind Offline
huimerind  Offline
est
Cast crank
LY rods
Cast stock replacement pistons
452 heads, hand lapped valves, no valve job
Comp flat tappet cam
170usd speedmaster rocker arms
Rpm dual plane intake
Old 9375 dominator
Headers
5200 converter, unknown, munsinger?
4.56 dana
Re: Any Race trucks in the forum? Any tips on building one? [Re: huimerind] #2969436
10/01/21 09:08 PM
10/01/21 09:08 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Beautiful launch!
