transmission cooler size ?
#2967281
09/25/21 12:10 PM
09/25/21 12:10 PM
Posts: 19,633 north of coder
moparx
the oil filter micron thread got me thinking about transmission coolers. why, i don't have a clue, but anyway, here goes. i have two coolers here, both 3/8" tube inlet/outlet size. one is 12"x4"x1 1/2" thick, and is a "two pass" [just in, loop around, and out]. the other is 12"x11"x1 1/2" thick and is a six pass. both are aluminum and use 3/4" tubes with aluminum fins in somewhat of the size of a radiator. the question is, could the small one be used as a stand alone cooler for a 727/reverse manual 3800/4000 stall converter, heavy street/occasional strip car, or should i use the larger one ? if i use the larger one, i have a [single] fan from a 90's minivan that fits perfectly, i could use if needed. stand alone in a good airflow is the key, as the radiator to be used does not have an in tank cooler. your opinions please, are greatly appreciated ! as always, TIA !
Re: transmission cooler size ?
[Re: moparx]
#2967291
09/25/21 12:37 PM
09/25/21 12:37 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
Do you have a trans temp gauge installed in the tranny? If so try the little one first and see what it runs with it I've made the mistake of using one that is to big and the tranny temps never got above140F ATF needs to be at least 160F for the additives to work according to the engineers at Torco years ago
[Re: Cab_Burge]
#2967293
09/25/21 12:46 PM
09/25/21 12:46 PM
moparx
operating temperature was something i was wondering about, so i need to get a deep aluminum pan first, then put a temperature gauge in. i'm thinking the little one might work with that pan better than a stock steel pan or a [somewhat] deeper A518 pan. i was also thinking about mounting it under the car to make plumbing easier.
[Re: moparx]
#2967309
09/25/21 02:13 PM
09/25/21 02:13 PM
Cab_Burge
[Re: Cab_Burge]
#2967314
09/25/21 02:44 PM
09/25/21 02:44 PM
Posts: 11,723 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Unless you're pulling a trailer for miles in the summertime. the small one.
[Re: AndyF]
#2967356
09/25/21 05:38 PM
09/25/21 05:38 PM
Posts: 1,030 ohio
67mprfan
ohio
Cooler size is 100% dependent on use. If the car is rarely driven then it doesn't need much of a cooler. Most street/strip cars don't need much of a cooler since they typically are not driven very hard. As soon as you start doing a lot of WOT driving, or towing or hill climbing then you need a big cooler. on the freeway then the temp would climb pretty fast. I'm watching this topic while waiting for my converter
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: CMcAllister]
#2967361
09/25/21 05:52 PM
09/25/21 05:52 PM
Posts: 30,491 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
Unless you're pulling a trailer for miles in the summertime. the small one. THERE you go ! .... unless the temp of the ATF has a factor of the up shifting or the torque converter operation...... And seaBee .... mopX has a tranny ??!! ... I always thought he was a STRAIGHT SHOOTER!
[Re: Cab_Burge]
#2967493
09/26/21 11:47 AM
09/26/21 11:47 AM
moparx
Cab, i am going to use one temperature gauge with two senders, one in the pan and one in the output line as has been stated, then switch between the two to observe the difference. the radiator does not have a cooler in the tank, therefor the size question. no towing, and no wintertime use, so no problems to crop up with those two scenarios. also, the only flex line to be used will be from the hard lines connected to the cooler. depending on how/where i mount the cooler is the next item to think about. use the small one if mounted up front in the air stream, and the big one if mounted under the car ? either one will be mounted horizontally. thanks for the replies fellows !
