transmission cooler size ? #2967281
09/25/21 12:10 PM
09/25/21 12:10 PM
moparx Offline OP
moparx  Offline OP
the oil filter micron thread got me thinking about transmission coolers. why, i don't have a clue, but anyway, here goes.
i have two coolers here, both 3/8" tube inlet/outlet size.
one is 12"x4"x1 1/2" thick, and is a "two pass" [just in, loop around, and out].
the other is 12"x11"x1 1/2" thick and is a six pass.
both are aluminum and use 3/4" tubes with aluminum fins in somewhat of the size of a radiator.
the question is, could the small one be used as a stand alone cooler for a 727/reverse manual 3800/4000 stall converter, heavy street/occasional strip car, or should i use the larger one ?
if i use the larger one, i have a [single] fan from a 90's minivan that fits perfectly, i could use if needed.
stand alone in a good airflow is the key, as the radiator to be used does not have an in tank cooler.
your opinions please, are greatly appreciated ! up
as always, TIA ! bow
beer
Re: transmission cooler size ? [Re: moparx] #2967291
09/25/21 12:37 PM
09/25/21 12:37 PM
Do you have a trans temp gauge installed in the tranny?
If so try the little one first and see what it runs with it twocents
I've made the mistake of using one that is to big and the tranny temps never got above140F shock ATF needs to be at least 160F for the additives to work according to the engineers at Torco years ago shruggy
Re: transmission cooler size ? [Re: Cab_Burge] #2967293
09/25/21 12:46 PM
09/25/21 12:46 PM
moparx Offline OP
moparx  Offline OP
operating temperature was something i was wondering about, so i need to get a deep aluminum pan first, then put a temperature gauge in.
i'm thinking the little one might work with that pan better than a stock steel pan or a [somewhat] deeper A518 pan.
i was also thinking about mounting it under the car to make plumbing easier.
beer
Re: transmission cooler size ? [Re: moparx] #2967296
09/25/21 12:59 PM
09/25/21 12:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
As Cab says, without knowing the temps, it's a guess.
But location/airflow obviously matters; I like 'em behind the grille, and use as much hard line as possible.
I'm inclined to think the 2-pass is too small for that application.
Buddy ran a high-stall drag-only car, about 8x8 multi-pass cooler on firewall with a fan, and it was marginal.
Crutched it with synthetic fluid.
Re: transmission cooler size ? [Re: moparx] #2967309
09/25/21 02:13 PM
09/25/21 02:13 PM
Dominic, Thumperdart , put a small single row aluminum tube type cooler in front of his radiator on his Dart years ago and ended up moving it and put it behind the front bumper mounted horizontal so the tranny fluid would run between 160 and 200 F in the summer time in the Mojave desert work
Try the deep aluminum pan first with the temp. gauge and go from there wrench twocents
I use the stock tranny coolers in the radiators if they have one, they actually will help keep the temps up in the winters up scope
I think one of the guys on here ended up using two tranny temp senders when testing coolers on his street and strip race car, one sender in the pan and one in the front output cooler line going to the cooler, I think he saw around a 40 degree differences when using the cooler with the cover off. 190 leaving the tranny going to the cooler and 150 F in the tranny pan with the sender in the rear of the pan upshruggy
IHTHs luck
Re: transmission cooler size ? [Re: Cab_Burge] #2967314
09/25/21 02:44 PM
09/25/21 02:44 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Unless you're pulling a trailer for miles in the summertime. the small one.
Re: transmission cooler size ? [Re: moparx] #2967317
09/25/21 02:48 PM
09/25/21 02:48 PM
AndyF Offline
AndyF  Offline
Cooler size is 100% dependent on use. If the car is rarely driven then it doesn't need much of a cooler. Most street/strip cars don't need much of a cooler since they typically are not driven very hard. As soon as you start doing a lot of WOT driving, or towing or hill climbing then you need a big cooler. If you don't have a tranny temp gauge then you don't know what you need. I had a temp gauge channel on my data logger in the Duster and the tranny temp was always cold when cruising around town. Only time it started to get any heat in it was freeway driving and then only after about 20 miles. But if you went WOT going up a long hill on the freeway then the temp would climb pretty fast.
Re: transmission cooler size ? [Re: AndyF] #2967356
09/25/21 05:38 PM
09/25/21 05:38 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Originally Posted by AndyF
Cooler size is 100% dependent on use. If the car is rarely driven then it doesn't need much of a cooler. Most street/strip cars don't need much of a cooler since they typically are not driven very hard. As soon as you start doing a lot of WOT driving, or towing or hill climbing then you need a big cooler. on the freeway then the temp would climb pretty fast.
I'm watching this topic while waiting for my converter
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: transmission cooler size ? [Re: CMcAllister] #2967361
09/25/21 05:52 PM
09/25/21 05:52 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
THERE you go ! .... unless the temp of the ATF has a factor of the up shifting or the torque converter operation......
And seaBee .... mopX has a tranny ??!! ... I always thought he was a STRAIGHT SHOOTER! penguin
Re: transmission cooler size ? [Re: Cab_Burge] #2967493
09/26/21 11:47 AM
09/26/21 11:47 AM
moparx Offline OP
moparx  Offline OP
Cab, i am going to use one temperature gauge with two senders, one in the pan and one in the output line as has been stated, then switch between the two to observe the difference.
the radiator does not have a cooler in the tank, therefor the size question.
no towing, and no wintertime use, so no problems to crop up with those two scenarios.
also, the only flex line to be used will be from the hard lines connected to the cooler.
depending on how/where i mount the cooler is the next item to think about.
use the small one if mounted up front in the air stream, and the big one if mounted under the car ? either one will be mounted horizontally.
thanks for the replies fellows ! up
beer
Re: transmission cooler size ? [Re: moparx] #2967511
09/26/21 01:14 PM
09/26/21 01:14 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Go for a nice ride then shoot your converter with a temp gun, then you will know which cooler to use.
