Re: Hog rings
[Re: Jim_Lusk]
#2966745
09/23/21 04:53 PM
09/23/21 04:53 PM
Posts: 1,404 Central Pa
moparjim79
Central Pa
Someone on here mentioned before you can get loads of them for pretty much pennies at tractor supply
Btw-Harbor freight sells the pliers for around $3
Re: Hog rings
[Re: nuthinbutmopar]
#2966762
09/23/21 06:21 PM
09/23/21 06:21 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
I have used both 1/2 and 3/4 when installing covers. The 3/4 seem a little easier to get started as the offer a little more "reach" when trying to get something attached.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Hog rings
#2966805
09/23/21 07:35 PM
09/23/21 07:35 PM
Posts: 4,713 Florida
BDW
I've been using small wire ties in place of hog rings for years. You can get them all started and then tighten them up to get everything straight... Interesting, why not just use zip ties, no special tools needed?
Re: Hog rings
[Re: BDW]
#2966845
09/23/21 09:07 PM
09/23/21 09:07 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
Interesting, why not just use zip ties, no special tools needed? [/quote]
I'm guessing there's a reason God created hog rings, and hog ring pliers. Upholstery guys ALL use them.
Re: Hog rings
[Re: Ronnman]
#2967518
09/26/21 01:41 PM
09/26/21 01:41 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
Currently installing new Legendary seat covers. One of Their installation kits comes with 3/4" hog rings and pliers. You need hog rings as opposed to zip ties etc, because it can be VERY hard to get that new vinyl stretched over new foam. You need 1 hand to pull/stretch and the other with the pliers. These are what came in the kit. Turns out they are made near where I live in Ontario, Canada!! I needed some more, and ordered them. Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
