Page 2 of 4 1 2 3 4
Re: Project Build.....Dragula Style [Re: Dragula] #2966667
09/23/21 12:07 PM
09/23/21 12:07 PM
moparx Offline
moparx  Offline
ET-3 style rear wheels. the ones with the "D" shaped slots with the rib around the slot. painted to resemble oxidized magnesium. boogie
beer
Re: Project Build.....Dragula Style [Re: moparx] #2966673
09/23/21 12:20 PM
09/23/21 12:20 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I say 605 Hemi with Stack inj
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Project Build.....Dragula Style [Re: moparx] #2966767
09/23/21 06:31 PM
09/23/21 06:31 PM
Rockford,Il
DFlanagan Offline
DFlanagan  Offline
Rockford,Il
Like these?- Wheels
Re: Project Build.....Dragula Style [Re: DFlanagan] #2967000
09/24/21 12:03 PM
09/24/21 12:03 PM
moparx Offline
moparx  Offline
yes ! boogie
beer
Re: Project Build.....Dragula Style [Re: moparx] #2967061
09/24/21 03:04 PM
09/24/21 03:04 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Project Build.....Dragula Style [Re: bigdad] #2967077
09/24/21 04:11 PM
09/24/21 04:11 PM
Taxes & Virus's R-US, NY
Dragula Online content OP
Dragula  Online Content OP
What I am learning, and I should have read up on it sooner, in the Drag Week rules, the chassis is not legal for A or B Gas based on the front rack conversion and the rear four link..... Kinda sucks. Was looking to maybe run it in one of those classes with this car. Not to mention some of the other rules like 11.25" wide max rear tire and no coil overs. I can tell you I am probably not changing any of that to fit the rules...In fact, I am not seeing a class it does fit. The fire wall is moved back, the front nose is stretched, and the hole in the hood goes right to the base of the window. A lot of these are no no's in the rules. ...funny how that works.
Re: Project Build.....Dragula Style [Re: Dragula] #2967100
09/24/21 05:46 PM
09/24/21 05:46 PM
lino lakes, mn
Schultz62 Offline
Schultz62  Offline
lino lakes, mn
I say Dragula build it and have fun. Yes I know it's easy to say that for someone elses build. grin I say hemi with a Potvin snout driven 8-71 blower. The lengthened front end gives you plenty of room.
Re: Project Build.....Dragula Style [Re: Dragula] #2967166
09/24/21 10:41 PM
09/24/21 10:41 PM
Rockford,Il
DFlanagan Offline
DFlanagan  Offline
Rockford,Il
Sounds like they need an old time exhibition class added.
Re: Project Build.....Dragula Style [Re: DFlanagan] #2967335
09/25/21 04:19 PM
09/25/21 04:19 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
You could run in Unlimited, or Street Machine Eliminator. You could run easy 10.00s in SME, it's much tougher to run at the top of Unlimited. That's a very cool car, but doesn't slot very easily in Drag Week. Still surviving Drag Week is job 1. Good Luck with whatever you decide.
Re: Project Build.....Dragula Style [Re: Skeptic] #2967353
09/25/21 05:27 PM
09/25/21 05:27 PM
birdtracker Offline
birdtracker  Offline
just tell the inspector its a rare factory one of one alter wheel base cars!!! Birdtracker
Re: Project Build.....Dragula Style [Re: birdtracker] #2967372
09/25/21 06:46 PM
09/25/21 06:46 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
Dragula, is Dragweek a must? If not, what about the Heads Up Index racing. 1/8 mile 5.50, 6.0, 6.5, and 7.50 seem to be pretty popular, and the rules are pretty open. Sounds like a perfect fit for that very cool car. I, myself am building in that direction with my Lancer as the old style look was the main reason I started this project. Specific class rules in other open classes made them WAY out of my budget. You could keep all the cool stuff ,race and still be competitive.Whatever you decide, you've got a very cool ride that you need to build and enjoy. Good luck, sir! Bill
Re: Project Build.....Dragula Style [Re: lancer493] #2967382
09/25/21 07:49 PM
09/25/21 07:49 PM
We will see I guess.
Re: Project Build.....Dragula Style [Re: Dragula] #2967712
09/27/21 08:35 AM
09/27/21 08:35 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Cool project. Daring to be different?
Re: Project Build.....Dragula Style [Re: HardcoreB] #2967717
09/27/21 08:43 AM
09/27/21 08:43 AM
Definitely...
And for the engine combo, I am thinking a blown 528 Hemi in this deal with an 8-71 on it....Race it on E85, drive it on 93, and have a very mild .690 lift blower cam. This kinda goes back to a discussion I started a while back as there are two ways to do this engine. Large pistons, small stroke, or large stroke, small pistons. I am leaning towards the larger pistons for valve clearance.
Re: Project Build.....Dragula Style [Re: ZIPPY] #2972101
10/08/21 03:58 PM
10/08/21 03:58 PM
So it goes to the chassis shop next week. The goal, get the cage updated so it certs to 8.50 and the addition of inner door panels and inner removable fenders....Already found 2-bars that are illegal in the car and will have to be removed and replaced. I also weighed the car as it sits, what a pig! its 2000lbs completely empty, so fiberglass parts are going to be needed. Obviously, the hood is a big culprit.
I also pulled the low back seats out and put the high back seats from my '70 Cuda in it, and dropped them right to the floor. So now I fit in there better, but the steering column is tool long. I need a seat with neck support if we put as much HP on board as i think we might. Also tried to fit my old radiator from my Cuda in there, and it needs a little persuading. I also put a PPP shifter in there and pulled out a switch panel that was in the trans tunnel. Going with a Leash setup for the whole car.
I will take pics when I get it back from Veto's
Re: Project Build.....Dragula Style [Re: Dragula] #2994726
12/12/21 08:37 PM
12/12/21 08:37 PM
Looky what showed up at the shop....
Re: Project Build.....Dragula Style [Re: Dragula] #2994794
12/12/21 10:56 PM
12/12/21 10:56 PM
BigFish69 Offline
BigFish69  Offline
Looks like callies showed up I also got one for christmas
Re: Project Build.....Dragula Style [Re: BigFish69] #2994803
12/12/21 11:20 PM
12/12/21 11:20 PM
Yes, Callies block. It looks really nice. Been trying to research a stroker kit for it, but so few sights have enough info on them to figure it all out on my own. Was looking for a billet crank 528 with the small 2.2 journals and about 9.5:1 compression pistons for a reasonable price. Seems like all the billet cranks use a 1.031 pin with the large Mopar journals. Not sure if I need to go that way or not at a shade under 1500hp....
Its going to be a bit before I build it. I thought I had my other car sold a number of times, and each time I got ghosted, so I am building a new 512 for that car as well as upgrading the wiring on it and the interior. Going to do a pump gas 512 with lightened crank and the usual Indy heads.
I always feel broke doing this stuff, but I still feel like I am living a dream....Just wish I had more money!!
Re: Project Build.....Dragula Style [Re: Dragula] #2994888
12/13/21 11:58 AM
12/13/21 11:58 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Just use a 440source crank. I have been extremely fast with one.
Re: Project Build.....Dragula Style [Re: Dragula] #2995117
12/13/21 10:33 PM
12/13/21 10:33 PM
[quote=Dragula]Yes, Callies block. It looks really nice. Been trying to research a stroker kit for it, but so few sights have enough info on them to figure it all out on my own. Was looking for a billet crank 528 with the small 2.2 journals and about 9.5:1 compression pistons for a reasonable price. Seems like all the billet cranks use a 1.031 pin with the large Mopar journals. Not sure if I need to go that way or not at a shade under 1500hp....
I always feel broke doing this stuff, but I still feel like I am living a dream....Just wish I had more money!! /quote]
That block looks a lot like the World iron blocks looked likework
Good luck on this build up
Page 2 of 4 1 2 3 4
