Page 4 of 5 1 2 3 4 5
Re: 426 Hemi rebuild... [Re: jlatessa] #2925160
05/21/21 12:22 PM
05/21/21 12:22 PM
moparx Offline
moparx  Offline
so you are familiar with the word "FRA GEE LEE", yes ? biggrin
beer
Re: 426 Hemi rebuild... [Re: moparx] #2925206
05/21/21 01:36 PM
05/21/21 01:36 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
My son puts one of those legs in his front window every Christmas,
so yes, I'm familiar.
Funny, that thing was delivered to him in the same box as the movie....
Joe
Re: 426 Hemi rebuild... [Re: jlatessa] #2925287
05/21/21 05:52 PM
05/21/21 05:52 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Originally Posted by jlatessa
Is that a red Ferrari in the backround?
Jeez, a hemi AND a Ferrari, I feel so inadequate...LOL
Good for you!
Joe Latessa, yes, I'm Italian
Haha, yes it's an old F355. Thank you.
Re: 426 Hemi rebuild... [Re: moparx] #2926068
05/24/21 09:04 AM
05/24/21 09:04 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Originally Posted by moparx
were any mods needed for the coil to the spark plug length ?
beer
I trimmed .125 off of the end of the coil. Also shortened the top of the plug tubes by .200.
The threaded spacers to mount the coils are .400 thick.
Re: 426 Hemi rebuild... [Re: INTMD8] #2926093
05/24/21 10:52 AM
05/24/21 10:52 AM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
Very cool!
With the coil on plug setup do you use a distributor? I can't see what's under the distributor hold-down.
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: 426 Hemi rebuild... [Re: YGBSM] #2926096
05/24/21 11:02 AM
05/24/21 11:02 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thanks. No distributor, just a cam sensor that Andy makes.
Re: 426 Hemi rebuild... [Re: INTMD8] #2926974
05/26/21 02:55 PM
05/26/21 02:55 PM
moparx Offline
moparx  Offline
thank you for the info ! bow
i'm not sure i can ever use it, but it's nice to know a relatively easy coil-on-plug setup can be installed on a hemi and look good as well. up
beer
Re: 426 Hemi rebuild... [Re: moparx] #2929653
06/02/21 09:43 PM
06/02/21 09:43 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
I moved the engine to a rolling table, installed clutch and flywheel. Did a cranking compression test on one cylinder just out of curiosity.
Also didn't like the look of the vacuum pump relief valve so put it inside a breather.
Also Brian Smith designed some header flanges for me but was unable to find someone to machine them for less than $1400 shocked Not really sure where to go with that so may just bail on my header building idea and order some TTi's.
Re: 426 Hemi rebuild... [Re: INTMD8] #2929705
06/03/21 09:32 AM
06/03/21 09:32 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
That EFI/COP setup is so beautiful this thread should be put in the tech archives for later reference.
2011 Drag Pak Challenger
Re: 426 Hemi rebuild... [Re: rickseeman] #2929748
06/03/21 12:02 PM
06/03/21 12:02 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Hasn't been much interest in maintaining the tech archives....And once it is archived, nobody can reply to it.
I would suggest, at whatever point it's comfortable to move, that it should be moved to the Member's project area instead.
It's over here
Supposedly pictures will be saved as long as the servers keep running, and the thread can be replied to continuously.
Rich H.
Esse Quam Videri
Re: 426 Hemi rebuild... [Re: ZIPPY] #2929917
06/03/21 09:57 PM
06/03/21 09:57 PM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Great thread ! up
As an aside, I believe the OEM AUDI/VW coil packs are a direct fit and don't require trimming like the Coyote coils do. It would perhaps depend on whether you are using Indy or Stage V heads as I believe the Indy plug tubes are taller.
I will be going down the EFI path at a later time on my 572 and am collecting parts atm.
Re: 426 Hemi rebuild... [Re: LAD 524] #2930621
06/06/21 08:44 PM
06/06/21 08:44 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The breather cap / relief valve is positively inspired.
The whole project is pretty awesome , but those little touches are what shoves a project to the front of the line for me.
Very nice !
Re: 426 Hemi rebuild... [Re: tubtar] #2940028
07/05/21 01:18 AM
07/05/21 01:18 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Well thank you, much appreciated.
I originally made a bracket (that I didn't take photos of) to brace the top alternator mount to the water pump..... Then noticed after tensioning the vacuum pump it was easily flexing on it's studs if I pulled on the belt.
Hmmm, don't like that.
Toss alternator support bracket in the trash and start over to include vacuum pump. Very solid now.
Re: 426 Hemi rebuild... [Re: INTMD8] #2942174
07/11/21 10:18 PM
07/11/21 10:18 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Finally caved and ordered some TTi headers. Very impressed by the construction and fitment. Thick flat flanges, not just a ground down weld beat at each port.
I welded o2 bungs in them and had them coated locally. Color is called "titanium" and they say rated for 1800deg. Installed with my favorite sealant, Toyota FIPG and no gaskets. Also used Zircoflex ceramic heat shield around the starter.
Re: 426 Hemi rebuild... [Re: INTMD8] #2942304
07/12/21 11:51 AM
07/12/21 11:51 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What bell housing and the size of clutch?
Re: 426 Hemi rebuild... [Re: cudaman1969] #2942306
07/12/21 11:57 AM
07/12/21 11:57 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
It is a Keisler bellhousing. Clutch is a Mcleod 6911-07 which is dual organic discs of 9.688 diameter.
Re: 426 Hemi rebuild... [Re: INTMD8] #2966193
09/21/21 10:56 PM
09/21/21 10:56 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Some more photos. Everything fits well so far. Also wired up an output to a relay to use the hood turn signal lights as a shift light as well smile
Re: 426 Hemi rebuild... [Re: INTMD8] #2966194
09/21/21 11:01 PM
09/21/21 11:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
very nice
Re: 426 Hemi rebuild... [Re: CSK] #2966205
09/21/21 11:29 PM
09/21/21 11:29 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Thank you, much appreciated
Re: 426 Hemi rebuild... [Re: INTMD8] #2966247
09/22/21 09:05 AM
09/22/21 09:05 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Your efi wiring looks better than mine, it was hard to find a good routing, I have so many relays ,diodes ad ons under the hood, it looks like a wiring factory exploded LOL
