The 1958-62 350, 361 & 383 "B" factory 2 X 4 iron manifold is a divided plenum single plane like the Offy.
I don't think a dual plane 2 X 4 is a good choice.
I wrote some comments on my site here:
http://victorylibrary.com/mopar/blower/blower-GMC.htmProbably of little impact for a street car, but it's been 30 years since Eaton showed what's wrong with helixed roots blowers: the highest efficiency for the discharge port is not a rectangle but a much shorter triangle located directly behind the drive end. All of the manifolds I've seen have this same serious design flaw.
The $$$ 14-71 Kobelco etc. do not. The entire blower is moved backward on the engine to position the triangle midway in the intake port row.
