Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2967730
09/27/21 09:00 AM
09/27/21 09:00 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Years ago when I ran big blocks I never ran any gaskets with the valley pan, just a dab of silicone in the corners of the china walls. I reused them multiple times and never had issues.
Re: reusing valley pan/intake metal gasket [Re: justinp61] #2967984
09/27/21 08:52 PM
09/27/21 08:52 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
That will work when EVERYTHING lines up just right. As soon as you cut something or throw in some aftermarket parts, gaskets can mean the difference between success and failure.
Master, again and still
Re: reusing valley pan/intake metal gasket [Re: DaveRS23] #2968234
09/28/21 08:21 PM
09/28/21 08:21 PM
West Palm Beach, Florida
Copper Dart Offline OP
Yes sir, Nothing was really changed just r&r for cam lobe inspection, gasket replacements and paint/detail work. The heads were not removed and all same parts reinstalled.
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: reusing valley pan/intake metal gasket [Re: Copper Dart] #2968334
09/29/21 07:57 AM
09/29/21 07:57 AM
an8sec70cuda Offline
Years ago I ran a 440 w/ some severely shaved 915 heads on it. Shaved enough that I had to notch the corners of the intake manifold to clear the china rails on the block.
When I tightened down the intake, it crushed the valley pan down at the corners, but port alignment was still correct.
I didn't use any gaskets on that one...ran it for years w/ no problems.
CHIP
'06 GMC 2500HD LBZ Duramax
