Key Fob Replacement 2016 Jouney
#2964483
09/15/21 06:18 PM
09/15/21 06:18 PM
Posts: 9,140 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Wifey has a 2016 Jouney that she likes. One of the key fobs has stopped starting the vehicle. It still locks and unlocks the doors but will not enable the starter button. I've checked/replaced the fob battery twice, no luck. The other fob works fine. I'm guessing we need to get a new fob? I see them on Amazon for about $40 with the note that they need to be programed by a locksmith or a dealer. Wifey call the local Dodge dealer and they want $250 to fix her up with a working fob.
Anyone dealt with this before? Can I buy a fob off of Amazon and get it programed easily or do I get stuck for $250 by the Dodge dealer?
Re: Key Fob Replacement 2016 Jouney
[Re: Ramrod39]
#2964487
09/15/21 06:25 PM
09/15/21 06:25 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Wifey has a 2016 Jouney that she likes. One of the key fobs has stopped starting the vehicle. It still locks and unlocks the doors but will not enable the starter button. I've checked/replaced the fob battery twice, no luck. The other fob works fine. I'm guessing we need to get a new fob? I see them on Amazon for about $40 with the note that they need to be programed by a locksmith of a dealer. Wifey call the local Dodge dealer and they want $250 to fix her up with a working fob.
Anyone dealt with this before? Can I buy a fob off of Amazon and get it programed easily or do get stuck for $250 by the Dodge dealer? I have on my 2012. I bought two on ebay for about $30 each and had the dealer program them - think they were about $60 each (ultimately they did it for free cause they did other work so threw it in). One died and the other is fine. You definitely need the correct programmer to do it - cannot self program. I tried to buy a scanner that has that capability, and gave up. It got real complicated trying to figure out what programmer would program what, and they were in the thousands of dollars. I was willing to spend money on a good scanner, but got discouraged and have yet to buy one. I would probably spend the $250.............
[Re: Ramrod39]
#2964601
09/16/21 12:24 AM
09/16/21 12:24 AM
Posts: 823 On the open road
Hrtbkr
On the open road
Check the web for reprogramming instructions. I've used web information to successfully program fobs for my 08 PT Cruiser. The locksmith I usually use refused to cut my ebay fob. I ended up at Home Depot and the guy cut it for frss. Good luck
While outside on the turnpike
They got this new hit tune
Where thrills become as cheap as gas
And gas as cheap as thrills
[Re: MI_Custumz]
#2964712
09/16/21 02:07 PM
09/16/21 02:07 PM
markz528
Morrow, OH
I know some of the cars I have owned said if you have 2 working FOBs, you can program another on your own. Works on older keys but not fobs. Fobs need dealer or locksmith programming, or anyone with the proper software.
[Re: stumpy]
#2964995
09/17/21 01:37 PM
09/17/21 01:37 PM
Ramrod39
My New Title
My New Title
Tucson, AZ
Fobs have keys in them. move the ribbed button to the side and Just pull it out. Yes, I know this, but that key only works on the door. Will not start the vehicle.
[Re: Ramrod39]
#2965167
09/18/21 06:17 AM
09/18/21 06:17 AM
Posts: 5,656 Port Huron, Michigan
MI_Custumz
There is no lock cylinder to insert a key into in the car. Only a button to push to start . Am I wrong? Am I missing something? I've read that you can pop out the button and there is a key slot under some of them. Never tried to remove one because I would probably break something.
[Re: markz528]
#2976823
10/21/21 01:30 PM
10/21/21 01:30 PM
Posts: 4 usa
ShaneHobbs
usa
I know some of the cars I have owned said if you have 2 working FOBs, you can program another on your own. Works on older keys but not fobs. Fobs need dealer or locksmith programming, or anyone with the proper software. I also worked on it and with the help of a locksmith i programmed those keys.
[Re: stumpy]
#2976943
10/21/21 07:33 PM
10/21/21 07:33 PM
Posts: 15,915 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
On my 2010 Pursuit which came with 4 fobs, 3 have stopped working I've tried several different new batteries (and brands), cleaning contacts, tightening contacts, all to no avail.
Facts are stubborn things.
[Re: stumpy]
#2977013
10/21/21 09:29 PM
10/21/21 09:29 PM
Ramrod39
My New Title
My New Title
Tucson, AZ
Yeah, that didn't work either. Ended up buying a new fob from the Dodge dealer. $252 with programming. Reused the metal key that only opens the door. Stupid fobs.
